| DougC |
Jan 18 2006, 02:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Hey I've noticed recently a moan as the car is bearly starting to move from a dead stop. It comes from the front end I think and I can almost since it through the steering wheel (as strange as that seems). The best way to discribe the noise is to say it sounds kind of like The Queen Mary or a large Ship leaving port (it's horn noise - but not near that load (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ). I think people on the street could probably hear it - kind of embarrassing if I roll the car super slowly. I'm thinking maybe a slightly warped rotor but are there any common items to check for? This car has 911T front suspension and brakes btw. Also, this car sat for 3 years before I started driving it recently...but everything was supposedly renewed during a restoration (track prep) before it was stored for the 3 years, so maybe something has dried out a bit too much.
Doug C |
| Aaron Cox |
Jan 18 2006, 02:37 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
a warped rotor would "pulse", and not be a constant groan....
bearing? wheel rub? |
| DougC |
Jan 18 2006, 03:25 PM
Well, I'm thinking it is sort of a pulse, because it goes away and comes back as the car moves, again only very slowly from a dead stop. Once I'm rolling 5-10mph it's no longer there or not detectable anyway. It's like the car rolls into the moaning area and then out again.
Doug C |
| SirAndy |
Jan 18 2006, 03:41 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| r_towle |
Jan 18 2006, 03:43 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I would say its either brakes or bearings.
both could do what you are saying, though more likely its brakes.. You could have glazing on the pads and rotors, you could have a bad piston in a caliper that is not retracting and is rubbing on the rotor... To check the brakes, go to a parking lot and stop the car without touching the brakes....first get it to stop maoning...then either glide to a stop, or use 1st gear and the emergency brake to stop it without touching the brake pedal... If after that as you are taking off and it moans, its probably bearing related... Rich |
| Eric_Shea |
Jan 18 2006, 04:39 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
| DougC |
Jan 18 2006, 05:00 PM
If it was a wheel bearing though, wouldn't I be able to wobble the wheel assembly while it's in the air - or maybe that's not always the case? I haven't tried it yet BTW.
Doug C |
| SirAndy |
Jan 18 2006, 05:02 PM
only if the WB was lose ... the "moan" you feel/hear is not a lose bearing, it's a bearing that is about to die. two completely different things ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
| Root_Werks |
Jan 18 2006, 05:21 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,905 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
If it sounds almost "harmonic", it might be a caliper that is hanging up just a tad? I had one vented rotor that lost the spring thingies inside the vents. It hummed all the time.
| DougC |
Jan 18 2006, 05:33 PM
I'll check those things out guys - thanks.
Doug C |
| Rand |
Jan 18 2006, 05:35 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
If you only hear it below 5-10 mph, then I'm siding with wheel bearing.
But then again, the tone of the sound may be a clue: growl = bearing, moan = brakes... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Does it change if you drag the brakes a little? Jack it up and rotate the wheels while you listen. |
| lapuwali |
Jan 18 2006, 06:02 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
The brake test isn't all that reliable. Wheel bearings can change noise from the load change when the brakes are applied.
Wheel bearings seem to fail in several ways, causing different noises. A loose bearing will cause a wobble. A bearing that's too "dry" or has a flattened roller will usually chirp or screech. A bearing that has a wear spot on the race will usually howl all the time, and generally get worse as wheel speed increases. Sometimes, the noise will change based on whether or not you're turning, as you load/unload the damaged bearing. A loud moan at low speeds that goes away once you get moving, esp. if it only does it after the car's been sitting for a few hours, can be a slightly dragging caliper, perhaps caused by a light amount of rust on the rotor that quickly gets wiped away. |
| Eric_Shea |
Jan 18 2006, 06:06 PM
Most of the time but not always. When I teched for the local PCA, I would rest my knee on the top of the tire and rock. You might hear a clunk. My 911 died at the Historics at Laguna Seca. I thought that's what it was but it actually tightened up the assembly before going all the way. Made it hard to initially diagnose. Either way, it sounds like one that's 'beginning' to go. |
Lo-Fi Version | Time is now: 5th March 2026 - 10:10 AM |
