Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
So what item?, the heads or the cylinders have more of an impact on engine performance and longevity when properly cooled?
If someone had a bolt-on kit for watercooling, would you rather have watercooled heads or watercooled cylinders? What temperature do the cylinders get to while the engine is working? |
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
This should make for an interesting thread... Didn't Porsche start out by cooling just the heads on their race cars?
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Muller,
My money is on heads. They are exposed to half of the flame front during ignition and they get ALL of the exhaust gasses. That wussy cylinder only gets exposed to a hot ball of exhaust as the piston drops ...and not all at once. Also, as the piston drops to expose more cylinder, the pressure in the cylinder is dropping and the charge cools a little from expansion. Thus, parts of the cylinder never get exposed to the temps that the head does Thats my story and I'm stickin to it. (IMG:style_emoticons/default/blink.gif) Ken Pull the pin, drop and run..... |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
I've got to go with heads. That must be why they have much more surface area of finnage on the 914, and also why sodium valves were used on the 2l.
Some head will be conduced to the head from the cylinder if we are talking about trying watercooled heads on a Type 4, plus the lack of air flowing throught he head will provide more airflow through the cylinder fins, so I think it may be quite an effective motor. Plus it will be porsche club legal. Fiid. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(scotty @ Aug 30 2003, 08:23 AM) Didn't Porsche start out by cooling just the heads on their race cars? yup - and motorcycles too. if you want to see max HP/cc normally aspirated, go look at what those guys are doing. and you -know- they had an uphill battle selling all the ancillary water cr&p (rads, hoses, reservoirs, header tanks, pumps...) to the motorcycle people. IIRC (could be wrong...) Honda or Yamaha were the first to go with water cooled heads on the racing bikes. everybody said 'no way' until they started winning all the races... |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Heads-hands down.
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
The heads are already oil cooled to a greater extent than the cylinders.
The cylinders are under more stress than the heads and if they overheat the rings won't work anymore. Also since cast iron doesn't conduct heat well the cylinders will heat up more than the heads with a temperature differential (inside-outside) of over 1200F. It is well documented that switching to aluminum cylinders (Nickies) will lower the head temps as well as having other benefits. I can't see any point in going to all the trouble of watercooling unless you want to achieve power outputs of close to 100hp per cylinder. LN Engineering claims that engine lifespan is greatly increased by switching to aluminum/Nikasil cylinders. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
QUOTE I can't see any point in going to all the trouble of watercooling unless you want to achieve power outputs of close to 100hp per cylinder. Who's getting 400hp out of a type 4? Or did you mean liter, ie 200hp? Andrew |
ChrisFoley |
QUOTE(Andyrew @ Aug 30 2003, 03:28 PM) Who's getting 400hp out of a type 4? AFAIK no one, but Porsche 6's in race trim can make more than 600hp. I believe Jake Raby has a T4 project on the drawing board that will be well over 300hp N/A, and air cooled. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I say the jugs, what Chris said.
I want to investigate lowering the air pressure under the engine more. M |
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
I've never heard of a cylinder temp gauge but i know there's such a thing as a head temp gauge
redshift |
So, what can you do to an alloy head to make it cooler? Mount it on a cooler cylinder? You'd have to do something about them, and it seems like that would be the obvious first step, the weakest link.
Cast iron is good for cooking, it holds heat like a jealous bitch. No offense to all the jealous bitches out there. (IMG:style_emoticons/default/smile.gif) M |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Heads, all the way. From all reports, cylinder cooling is more than simply "adequate" if you switch to aluminum cylinders. Nothing else is needed. Now the heads, on the other hand.... They're already aluminum, and they need still more help! Giving them a nice aluminum heat sink (i.e., an aluminum cylinder!) helps them, but they could use more yet IMHO.
'Cause then we can go four-valve!! (IMG:style_emoticons/default/biggrin.gif) --DD |
redshift |
But Dave.... I don't have alloy cylinders to start with.
The heads are the weak link on our cars for many reasons.. just guessing really, but I think mounting the heads on a better heat sink would bring the mean temps down.. there is a very small break-point in head temps vs mixture density, right.. every BTU helps.. (IMG:style_emoticons/default/smile.gif) We need to set up shop in Peenemunde.. M |
Dave_Darling |
No guess-work required. LN Engineering and Raby have both done testing on Type IV engines. The ones with aluminum cylinders (LN's "Nickies") have run cooler head temps with no other changes. (Well, no two engines are ever going to be completely identical, but no other major changes.) The aluminum heat-sink, I believe, is what helps the heads cool a bit more.
The original talk on this thread was water-cooling. It isn't needed for the cylinders IMHO--a cheaper solution is available, just get "Nickies". Water cooling probably can help if done on the heads. Plus that's the way the Porsche Factory did a number of their Turbo motors. (IMG:style_emoticons/default/biggrin.gif) --DD |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Porsche went to water cooled heads on their air cooled racing engines when they went from two valve to four valve heads. Too much stuff in the way to allow enough cooling fin area for air cooling. I can't remember if this was done for the still-born Indy project and transferred to the later 936 cars or was a 956 developement.
Mike |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
The piston rings only move in a 71mm area at the top of the piston bore (which is why the fins are bigger at the top) on a 2.0 engine.
Heads. B |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
I look at it this way. Review Porsches history.
(over simplified) First they built engines with iron jugs and aluminum heads. This got them to little more than 40hp per cyl. (early six) Porsche has NEVER gotten huge power out of an engine with iron cyls. They don't shed heat. As HP increased the iron jugs were replaced by aluminum. This got them to as much as 75-100hp per cyl. (911turbo-917) To get past the 75-100hp/cyl. cooling limit they watercooled the heads (935-959) for upwards of 125hp/cyl. Then the 962 got watercooled heads AND cyls and could manage 125hp/cyl. and could do it for 24 hours straight. (this was all off the top of my head so correct me if there are any errors) So it seems to me that first you need aluminum jugs, then you need watercooled heads, then you need watercooled everything. -Ben M. |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Cooler cylinders translate into cooler heads- period.....I have done the testing......Cooler temps result in better power and better fuel economy.
fiid |
So we all hate cast iron cylinders. How tough would it be to add a water jacket to these??
My only objection to Nickies is the cost - and the fact that they can't be machined when they are done with how ever long they are good for (is that correct??). If you are going to run a water circuit, it wouldn't be hard to add cooling for the cylinders once they are able to do something with the water. Possible? Not worth it? Fiid. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:08 AM |
