> OT: Formula 1 tire profile, question
Rand
post Jan 28 2006, 04:50 PM
Cross Member
Somebody school me on formula 1 tires... why the tall sidewalls? In street tires, the more extreme, the lower the profile. Shorter sidewalls, less flex, more cornering traction... Seems like in anything except F1, the tires are very low profile.
Replies(1 - 19)
dinomium
post Jan 28 2006, 04:52 PM
Git on a chair son, all the good stuff is goin over yer head!
trying to keep the racing competitve with grooves and tall sidewalls...
r_towle
post Jan 28 2006, 04:57 PM
Custom Member
lower sidewall, less flex, therefore less grip.
Low profile tires looknice, but do not grip as well as properly proportioned tires.
Rich
dlo914
post Jan 28 2006, 05:00 PM
Whatchu' lookin' at?!?!
hmm...good question. after some thinking i remember seeing ricers (hondas) removing their blinged out rims in the front w/ steel rims and regular radials to gain more traction. And since top fuel dragsters need all the traction they can use at the rear they've got fatties. Similar to dragsters, the F1 cars have about the same amount of HP. Concluding my assumption...
Aaron Cox
post Jan 28 2006, 05:03 PM
Professional Tinkerer
QUOTE (dlo914 @ Jan 28 2006, 04:00 PM)
top fuel dragsters make up to 6000hp. the motor life is measured in seconds..... usually, they have 4 injectors per cylinder, run on alcohol/methanol etc and run 70+ pounds of boost.
F1 cars dont make anywhere close to that.... BUT they last alot longer....
Rand
post Jan 28 2006, 05:09 PM
Cross Member
I almost mentioned "except drag cars" in my original post but didn't think it would go there. Also keep in mind that the front tires on an F1 car are higher profile than the rear tires of a GT car.
messix
post Jan 28 2006, 05:13 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
QUOTE (Aaron Cox @ Jan 28 2006, 04:03 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) actually top fuel is 85% nitro and 15% methonal.
f1 i believe has a 13"rim rule so side wall hieght is related to contact patch. f1 tire rules i think also state tire dementions, nascar does the same.
google racing tires and i/m sure all this will be explained. oh. and heat durabily from heat and cornering forces track debrie all kinds of stuff.
dlo914
post Jan 28 2006, 05:17 PM
QUOTE (Aaron Cox @ Jan 28 2006, 03:03 PM)
FI cars are in the 1000hp range?
messix
post Jan 28 2006, 05:19 PM
i thouhgt f1 was 650-700hp
dlo914
isnt the technology/knowledge gained from F1 tires influencing the making of street tires?
Rand
Cross Member
Thanks Troy. That's making sense.
Shoulda Googled it, but it's more fun to discuss it in the garage. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
messix
post Jan 28 2006, 05:28 PM
no prob. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
ok let lets chew it.
the grooves stupid plan the tire manf. just made thre tires so that when the tire wore down past the grooves they had the same grip as a slick. duh wouldn't you . soo f1 makes them change the tire and have to finish the race with _ amount of groove left.
alpha434
post Jan 28 2006, 07:22 PM
My member number is no coincidence.
Isn't the tire restriction standard for all formula type racing? Those formula Vee guys have to race with stock wheels and tires. I don't know, really. I'm kinda impartial to open wheel racing. At least for today.
dinomium
post Jan 28 2006, 07:28 PM
Fomula1.com
It the offical FIA site so of course it is completely useless!
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
lapuwali
post Jan 28 2006, 08:53 PM
Not another one!
The tires have tall sidewalls because the rules dictate maximum and minimum diamter of the tire, and the diameter of the rim. When the rules were laid down in the 1970s, they made sense based on tire technology of the day. Now, they're an anachronism, but kept as they are because: small rims mean small brakes, thus restricting outright speed (theoretically), which was a great idea until carbon-carbon brakes made them work so well even with the small diameters; tall sidewalls mean more flex, which keeps speeds down due to more limited cornering forces, except the tire makers manage to get more stiffness, and now more than 80% of the suspension travel in an F1 car is in the tire sidewalls (direct quote from an F1 designer); the FIA is a bunch of bloody-minded idiots.
There's been talk recently of changing the tire rules, but only to reduce rim diameter even more, or do some other stupid thing to try to make the cars slower. The rules basically aren't there to allow fully optimized cars. They're there to throw up big barriers the designers have to overcome.
The rules now restrict virtually everything on the cars, so you don't see innovative ideas anymore, because they don't fit the rules.
Next year, with the one tire manufacturer again, the rules makers can dictate things like tire compounds to control speeds, and will do so. Grooves will apparently disappear soon, and tire changes are back for next year.
As for power, the 3.0 V10s of 2005 were all making roughly 900hp. The 2.4 V8s for '06 and beyond appear to be in the 600hp range, though it's expected that will rise swiftly. For comparison, the 3.0 Cosworth DFV V8 of 1968 made 400hp, and was the most powerful engine in F1 at that time. Within a couple of years, the Cosworths were making so much power people were contemplating 4wd or six-wheeled cars (with four drive wheels in back, Williams built a prototype of this) to try to get acceptable traction out of the tires of the period. More downforce and better tires fixed that, and by the height of the turbo era in 1984, the engines were making as much as 1200hp in qualifying, for a few laps. They've never been that powerful since.
J P Stein
post Jan 28 2006, 09:36 PM
Irrelevant old fart
James:
These discussions are no fun when someone that knows what they are talking about shows up. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
alpha434
post Jan 28 2006, 10:04 PM
QUOTE (lapuwali @ Jan 28 2006, 06:53 PM)
Yeah. Thats what I thought. And now we can talk about the unfair FIA biasing towards Ferrari and the planned move to a different racing organization in 2010. Or 2008. One that will be sponsored heavily by japanese auto manufacturors. Yeah thats right.
Elliot_Cannon
post Jan 28 2006, 11:09 PM
Group: Retired Members
The only limits I would like to see is horse power. Everything else should be unlimited. There should be no retrictions on aerodynamics, tires, brakes, suspension etc.
Cheers, Elliot
Jeroen
post Jan 28 2006, 11:18 PM
Region Association: Europe
F1 tires have a fairly stiff sidewall (unlike drag tires)
Most of the suspension travel on an F1 car comes from tire deflection
Current carbon suspension arms are designed to flex a certain amount. They're more like leafsprings than hinges
As noted... all just stoopid rule restrictions that the manuf. need to work around
On LeMans prototype cars you'll see 18 and 19inch wheel/tire combos
Rand
post Jan 28 2006, 11:24 PM
Cross Member
Makes me wonder what F1 cars could do if all restrictions were removed.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:10 PM
