> undercoating removal, fastest way to go?
VaccaRabite
post Feb 16 2006, 07:12 AM
En Garde!
I have started removing the undercoating on my car, and so far I only have the front fenders cleared.
On one fender, I used a scraper, on the other I used a wire cup brush on an angle grinder. Is there a preferred way to remove this stuff?
I did search on this, but did not find any threads that said the best way to do it. I don't have media blaster, and don't fancy the mess involved with that. If there is an easier way then scraping and grinding, I'd love to hear it.
Zach
Replies(1 - 4)
jasons
post Feb 16 2006, 07:28 AM
Jackstand Extraordinaire
I haven't used it but Eastwood sells something you spray on undercoating to soften it.
Jeroen
post Feb 16 2006, 07:56 AM
Region Association: Europe
the wirebrush on an angle grinder or drill works best
it's a tedious job though and takes some elbow grease
you don't want to soften the undercoating
if it's soft, chances are you will smear it all over the place instead of brushing it off
media blasting won't take it of either because the undercoating is soft/flexible
media blasting only works on hard/solid surfaces, like paint, bondo, etc...
sharper
post Feb 16 2006, 08:01 AM
I used a heat gun and scraper and it pretty much peeled off in sheets.
Gint
post Feb 16 2006, 08:52 AM
Mike Ginter
Depends on the undercoating and the area it's in. But generally speaking...
Try scraping first. A lot of undercoating is dried out and flakes off easily (relatively speaking) in fenderwells especially.
Heat gun and a scraper to get the bulk of it off if it's soft.
4" heavy wire cup brush on an angle grinder for the rest.
The remaining residue will come off with brake cleaner.
It's work, but it's easily do-able.
- Lo-Fi Version Time is now: 6th July 2025 - 12:25 PM
