`76 2.0 - Mis-firing, not running well |
PhoenixINX |
Feb 28 2006, 08:57 PM
Newbie Group: Members Posts: 9 Joined: 19-January 05 From: Nashville, TN Member No.: 3,470 |
Here's the scoop... `76 2.0 - start it up, idles right at 500 and tries to stall.
After warming up for 5 - 10 minutes, and driving for another 10 - 15 the idle will FINALLY creep up to 1100. This had me thinking aux air valve. We removed it, cleaned it, checked connections and functionality... it's fine. Still doesn't fix the problem. Also note the car feels like its running on three cylinders! (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I started pulling the plugs tonight (after letting the car cool for 2+ hours) and am unable to comfortably remove the two rear plugs. Feels like they are still WAY too hot... does this engine take THAT long to cool? If still not plugs... any other things I could start checking? Thanks in advance! |
messix |
Feb 28 2006, 09:30 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
plug wires, points and condenser. cracked cap.
r_towle |
Feb 28 2006, 09:37 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
before you pull your hair out...
check that the MPS holds a vacuum. Make sure all your vacuum lines are attached. If the MPS is bad, it will run like a pig, it wont idle correctly, and it will idle high when warm... Aside from that...clean and reset the ignition. rich |
tesserra |
Mar 1 2006, 12:45 AM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
I had a similar problem with my 76 2.0.
Intake manifold was missing 1 bolt and the others were loose. Check for vacum leaks. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:32 PM |
