zeroing out my odometer, who knows how? |
lotus_65 |
Mar 12 2006, 06:21 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i have an extra 150mph speedo and i want to reset it to zero for when my 2056 is finished.
I have taken it partially apart for cleaning, and have read most of the pelican article. do i just spin the odo back with a drill?! if not, how do i pull off the needle w/o breaking and how to reset the digits manually? will i have to recalibrate the speedo as the article suggests? thanks paul |
davep |
Mar 12 2006, 07:04 AM
914 Historian Group: Benefactors Posts: 5,148 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'd spin it forward with a drill. But you should document the miles on the original odo when you replace it.
vertigo |
Mar 12 2006, 09:33 AM
Member Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 |
If apart pull the pin that holds the tumblers and turn them till all read ( 0 ) from front. If speedo is calibrated correctly now use a drill and spin it up to see where it registers (do this before odo work). Write speed down to check. (use fresh charged drill for this for accuracy) When odo is done put back together and check speedo.
Dave-O |
Mar 12 2006, 10:05 AM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Paul,
I've done this before, we can work on it when I get back from spring break. |
michel richard |
Mar 12 2006, 11:42 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
There's a good tech article for this on the Pelican Parts site.
lotus_65 |
Mar 15 2006, 12:15 PM
done. added a little custom paint and a new lexan peice. kleeeeen.
thanks, vertigo. one more question~ Attached image(s) |
lotus_65 |
Mar 15 2006, 12:16 PM
i didn't notice this when i took this apart, but the hole for the high-beam light doesn't line up correctly! the hole/tube lines up with a spot near the "MPH" text at the bottom, not the little lens at the top.
anyone have insight? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:25 PM |
