> replacing trans. endcap/cover
75boxster
post Mar 12 2006, 01:53 PM
I basically know very little about the 5-speed in my 75. What I do know is one of the ears
that are used to mount the tranny to chasis has broken.
I have what I belive to be a replacement cover. Is this just a R&R
deal or is there some hidden issues to swaping this piece that will
suprise me when I start?
Thanks guys. Tried a couple of searches but I am probably just calling this
piece by the wrong name.
Chris-
Replies(1 - 6)
itsaporsche914
post Mar 12 2006, 06:43 PM
where did my post go ?
itsaporsche914
post Mar 12 2006, 06:46 PM
ill try again . i have the same problem as you chris . i think it can be replaced easily. im gonna try when i get the part. my mechanic said 3 hrs and 250.00 i tried to post pix of mine . didnt work . i will keep trying good luck let me know what happens
So.Cal.914
post Mar 12 2006, 06:54 PM
"...And it has a front trunk too."
I changed the first /reverse gear in my trans, the easy part was the tail cover. I sudjest you replace the gasket.
itsaporsche914
post Mar 12 2006, 07:02 PM
chris does this look familiar?
Dave_Darling
post Mar 12 2006, 07:18 PM
914 Idiot
New gasket, new O-ring for the speedo drive shaft. I forget if there's anything else you do to seal up the speedo drive or not. Support the trans securely when you unbolt the old tail cover.
--DD
75boxster
post Mar 12 2006, 09:07 PM
That looks exactly like what happened to mine.
It also took out the front motor cross bar so the
whole frickin motor on the drivers side is on the gound.
I am really begining to hate this car.
- Lo-Fi Version Time is now: 16th April 2026 - 07:48 PM
