> need help IDing transmission
Chris Hamilton
post Mar 13 2006, 08:27 PM
While looking for some gear ratios I just pulled out an old 912 transmission from the sideyard, and I have been unable to find anywhere that lists the ratios. It says 902/16, and while I've found 902/01 and 902/02 online, I haven't come across anything close to 902/16.
Does anyone know the letter or number ratios for this transmission?
Thanks
Replies(1 - 6)
T H O M A S
post Mar 13 2006, 09:24 PM
901/0 1964-65 Five-speed transmission for Type 911
901/01 1964-65 130-hp engine for Type 911
901/02 1966-67 160-hp engine for Type 911S; five-speed transmission
901/03 1967-68 110-hp engine for Type 911T; five-speed transmission
901/05 1966 Type 901/01 with Weber carburetors
901/06 1966-67 Type 901/05 with revised valve timing
901/07 1967-68 Type 901/06 equipped for Sportomatic
901/08 1967-68 Type 901/02 equipped for Sportomatic
901/09 1968-69 Fuel-injected engine for 911E
901/10 1968-69 Fuel-injected engine for Type 911S; four-speed
transmission
901/13 1967-68 Type 901/03 equipped for Sportomatic
901/14 1967-68 Type 901/06 (130 hp) with US. emission control
901/17 1967-68 Type 901/14 equipped for Sportomatic
901/20 1966 210-hp engine for Type 906, Carrera 6
901/21 1966-67 Fuel-injected Type 901/20 for Type 906E and 910/6
901/22 1967 210-hp engine for Type 911R
901/30 1968 150-hp Rally Kit for Type 911L
902 1964 B-program production car with Type 616/36 four-
cylinder engine
902/0 1965-66 Four-speed transmission for Type 912 and 911
902/01 1967-68 Four-speed transmission for Type 912
902/02 1967-68 Five-speed transmission for Type 912
902/1 1965-66 Five-speed transmission for Type 912 and 911
903 1965 Experimental three-speed torque-converter automatic
transmission
Aaron Cox
post Mar 13 2006, 09:25 PM
Professional Lawn Dart
ill buy it off you....
912 is prolly A H Q X
propricer
post Mar 13 2006, 10:31 PM
According to my records, it is rather rare with a 6:29 R&P and gears of A, GA, O, U. Z.
Suggest you check with CarQuip, etc. to determine how much a new 6:29 is worth !!!
Good luck ...
Chris Hamilton
post Mar 14 2006, 12:34 PM
Thats interesting.
Aaron, It is a 5-speed. If you want to buy it however make me an offer via PM.
Propricer, thanks for the info, I will likely go ahead and open it later this week to see, sounds like its most likely worth the effort.
Aaron Cox
post Mar 14 2006, 12:36 PM
i think it just became out of my price range (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Chris Hamilton
post Mar 23 2006, 10:18 PM
QUOTE (propricer @ Mar 13 2006, 08:31 PM)
Good luck ...
Thanks for the info, I opened it and you're right. Sadly R&P was worn out, however the gears were just fine.
- Lo-Fi Version Time is now: 11th July 2025 - 03:34 AM
