Threaded perches, For stock sized springs |
r_towle |
Mar 15 2006, 01:40 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
I would like to know if the threaded perches for the rear bilstiens shocks will work with the 180lb weltmeister springs, and the stock spring perch... I do no want to buy different springs, I just want the ability to corner balance my car. Rich |
Aaron Cox |
Mar 15 2006, 01:42 PM
you will need to open up the stock lower perch to fit over the collar id guess....
r_towle |
Mar 15 2006, 04:01 PM
Is there a perch that will fit, made for the weltmeister diameter springs?
Where is the manufacturers web site again.... Rich |
Mueller |
Mar 15 2006, 04:13 PM
more Mueller madness....stock dia springs with threaded perch
1st pic shows opened up perch next to stock one (IMG:http://www.914world.com/bbs2/uploads/post-2-1119289911.jpg) assembled unit (IMG:http://www.914world.com/bbs2/uploads/post-2-1119290031.jpg) |
r_towle |
Mar 15 2006, 04:30 PM
Sure, if I had a lathe.... Make some out of aluminum...Its a new product and a new week.... Rich |
Porcharu |
Mar 15 2006, 04:44 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
[QUOTE=Mueller,Mar 15 2006, 02:13 PM] more Mueller madness....stock dia springs with threaded perch [QUOTE]
Looks like a product for you to make Mike. Get that CNC going or I'll beat you to it! Mike and I have the same mill that we are converting to modern PC control and can't seem to just get it done. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
r_towle |
Mar 15 2006, 04:53 PM
What type of mill?
I am looking to get a smaller hobby type mill... Need a good, cheap machine that is alot more accurate than a drill press, and can take the side load... Rich |
Lo-Fi Version | Time is now: 6th June 2024 - 12:03 PM |
