Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Yesterday after the fun run I went back to MikeD's place for a little while and when I left, after about the 3rd stop my pedal suddenly went to the floor (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) and the brake light started flashing. Brakes pumped up okay and after about 25 miles on I-5 came bake completely but the light still flashes. Stopped the car when it first happened to see if I was leaking fluid from somewhere but couldn't find any.
Ideas? |
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
MC going bad?
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,308 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
The switch on the MC needs to be reset to stop the light from flashing. I'm more concerned about the pedal going to the floor. That sounds like really bad news. Was there any hint of softness before or after?
Allan |
None. Brakes were solid all through the twisties... |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
YOU NEED A NEW MASTER CYLINDER!!!!!!!!!!!!!!!!! Replace it NOW! Or maybe just up your liability insurance. The Cap'n
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,046 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
it does sound like MC issues.
pull the pedal board and then pull the rubber sleeve over the MC to check for fluid leakage... If thats not it then my 2nd guess would be that one of your calipers is dragging. (rear venting clearance too tight, or stuck front piston) To check for this, put the car up on stands.. pull the wheels.. and pull each of the pads (yes all 8) compair thickness to see if one pair or even 1 pad shows increased wear. my logic is that if you had a stuck piston, that caliper over heated.. Especially if it was a rear pad.. then due to over heating the fluid boiled and you lost the brakes until everything cooled down. when you were parked did you have the parking brake on? a track rule is to never set the parking brake when you come off the track... things are too hot and need to cool down. setting the parking brake allows for more heat transfer and boiled fluid. 2 cents brant |
Allan |
I'll go over everything.
If it is in fact the master cylinder can I go to the 19mm with stock brakes since I'll be doing a 5 lug conversion pretty soon? |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
MC. Check for a wet pedal assembly.
Go 19mm now if your intentions are to have M-Calipers etc. You don't want to replace a MC again anytime soon. You'll see what I mean. |
davep |
Well, one guess may be a bit of crap in the MC got caught in a seal and prevented pressure buildup. Even if you replace the MC, be sure to thoroughly clean the reservoir first and flush like crazy. Thank goodness you just got a warning and not total failure. Keep us posted if you find any reason for the scare.
Allan |
Didn't get a chance to put the car in the air but went home for lunch and saw a puddle of fluid under the right front suspension. Stuck my head under there and it looks like it's coming from the transition where the rubber and steel lines meet. The whole strut assembly looks like it's been sprayed.
I think it'll be an easy fix... |
brant |
Daniel gets credit too...
but imagine that... the captain was right (for the 10,000 time in a row!) thanks captain for all the help, advice, and direction you endlessly supply! not said with sarcasm. brant |
Allan |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I don't thinks it's the m/c. Just a line... |
Cap'n Krusty |
Symptoms don't indicate a line. When a line fails, you lose braking and it rarely comes back until you do the repair. Master cylinders can fail by bypassing internally, and there will be no fluid loss when that happens. it may come back and work well for some time, only to fail again. Sooner or later, that can result in the use of a fixed object, or another moving one, for stopping your uncontrolled progress. The Cap'n
Eric_Shea |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) with her... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Allan |
So why is the m/c dry and I have fluid all over the right front strut. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Cap'n Krusty |
THAT symptom, one you didn't mention at the start, does indicate a leak. However, the fact the brakes "came back", doesn't fit the facts. The Cap'n
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
we'll i'll ask the stupid question...
where's the best place to get a 19mm master cylinder? (green-horn CSOB asking) do we ask for a particular year 911/19mm MC? This post has been edited by Dr. Roger: Mar 20 2006, 08:28 PM |
Allan |
Pelican sells them for $175.00.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
so tighten up the line, and bleed and report back....
at your disposal if you need my help to swap anything.... |
Allan |
Okay, I got the front wheel off and took a look around at the caliper and lines. The only thing I could see is the fluid looks like it is coming from the fitting where the flex line meets the steel line to the caliper. Fitting was tight.
Is it possible that the failure is where the rubber line is crimped to the fitting? |
Lo-Fi Version | Time is now: 31st August 2025 - 04:42 PM |
