Transmission Shifting, Synchro Symptoms |
nick mironov |
Mar 26 2006, 08:07 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
Do failing synchros always result in a "crunching/grinding" symptom or can the symptom be simply "hard to get into gear" with no crunching/grinding?
As my transmission warms up, it can be difficult toget it into 2nd or 3rd gears when standing still. It is very erratic. You can get it into gear 5 times in a row, and the next time it will not go in - no discernable pattern. I have all new bushings, a new Weltmeister short-shifter, and fresh transmission oil. This is a V8 conversion so I do not use 1st gear. (The original 2nd gear is my 1st gear - hence the need to put it into the original 2nd gear at a stop). |
Bleyseng |
Mar 26 2006, 08:33 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
or you need to adjust the clutch.....
worn dogteeth and worn sliders make for crappy shifting like you describe. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 01:20 PM |
