Exhaust Stud, Help locating a Step Stud |
solex |
Mar 27 2006, 04:14 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have been having trouble locating a step stud of the proper lenght (stock). The PO for some reason drilled and tapped one of the studs to a 10 x 1.5 and used a 10 x 1.5 stud but it was near impossible to remove the heat exchange without cutting the nut.
Any way, does anyone know of a source for a step stud 10 x 1.5 to 8 x 1.25 at least 38 mm long from shoulder to tip? It would save me removing the head to get the hole filled and re-tapped. Thanks, Dan |
MarkV |
Mar 27 2006, 04:17 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
dstar |
Mar 28 2006, 10:20 AM
Member Group: Members Posts: 196 Joined: 19-January 06 From: Ramstein, Germany Member No.: 5,438 Region Association: Germany |
In a pinch you could use Type I rocker arms studs.
You'd have to shorten the 10mm side's length, but it's easily doable....... Don |
Jake Raby |
Mar 28 2006, 10:27 AM
I hooked him up.. These studs are a hot seller for us, no one else has them..
solex |
Mar 28 2006, 10:35 AM
I'm all hooked up cannot wait to get it and finish my exhaust backdate project. Will post pics when done.
dstar |
Mar 28 2006, 10:49 AM
COOL!
I was thinking of getting at least 4 to have in the tool box. Never know when someone is gonna need one! Almost called Becca to have her add it to my order, but she scares me.... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Don |
bondo |
Mar 28 2006, 02:07 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Wasserboxer rocker studs work too, but also need shortening of the 10mm side. |
jd74914 |
Apr 18 2006, 10:26 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Anyone know the part #s for these step studs, T4store isn't loading right on my computer and I'm going to need some pretty soon.
solex |
Apr 18 2006, 11:19 AM
I had to contact Jake directly they are not on the web site.
Lo-Fi Version | Time is now: 1st June 2024 - 09:25 AM |
