advice, carb jetting |
tom444 |
Apr 2 2006, 08:50 AM
Newbie Group: Members Posts: 27 Joined: 16-November 05 From: phoenix az Member No.: 5,140 |
will incorrect jetting of webers make my 1.7 run hot and ping after 10mins of runing ,by the way the timing is correct. the webers are new the guy that sold it to me put them on just beforei got the car. tom444..
Joe Bob |
Apr 2 2006, 08:53 AM
Sounds like timing to me...
rick 918-S |
Apr 2 2006, 08:57 AM
Hey nice rack! -Celette Group: Members Posts: 20,464 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
timing or carb lean condition... Big ass vacum leak.
r_towle |
Apr 2 2006, 08:58 AM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
Yes a lean running condition will make your engine run hot. A 009 distributor does not have the right advance curve for a type 4 motor, sorry to say. If you do a search here, you will see that many people will tell you to get rid of the 009 distributor. 44mm webers are to large for the 1.7.. They can work, but you will need small venturis, and small jets to make it right. You need to look at the whole system. tuning a car with the wrong distributor and the carbs not set up right is impossible. You need to know the following. Carbs main jet size f tube size venturi size idle jet size. On the dizzy, and 050 will be alot easier to tune correctly, ideally a mallory or other, properly set up will be the best. Pinging is due to the ignition system , not the carbs... Rich |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:33 PM |
