Gas tank refinishing |
WRX914 |
Apr 4 2006, 03:16 PM
2.5 WRX STI hybrid powered beast Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
What clear coat should I use on my gas tank? I would think that there is a special use clearcoat that will resist gasoline?
Also, can you clearcoat the gascap? Mine keeps dulling over time... Keith |
d914 |
Apr 4 2006, 08:38 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
por 15 I believe makes a product.. Strip, Metal ready, por 15 gas tank reconditioning......If I wasn't so old and I just didn't smoke tha cigar I probably could remember!!! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Qarl |
Apr 4 2006, 08:57 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Here's what I did to make the tank like new...
Cleaned the inside of the tank with POR tank refurbisher kit. (or you can have it hot tanked at a radiator shop). Get it powder coated in semigloss black Then apply POR fuel tank internal sealing/coating on inside of tank. You need to get the tank powder coated FIRST as the heat fromt he oven will melt the fuel tank sealing kit. Will look like this when finished... (IMG:http://www.my914-6.com/images/dscn1944.jpg) |
yarin |
Apr 4 2006, 08:58 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I just put my gas tank back in the car. I sloshed some hot water with soap and some Simple Green around inside a bunch of times. There was no rust on the inside.
As far as the outside goes, it would look hot powdercoated glossy black. Too bad my oven isn't big enough. |
WRX914 |
Apr 5 2006, 10:36 AM
The inside is fine...
I just wanted to address the exterior of the tank. I have epoxy splatter paint on the exterior now and thought that I might need to clear coat the exterior to protect the paint. Keith |
Qarl |
Apr 5 2006, 12:25 PM
I think Epoxy is fairly resistent.
Here's a hint: don't pour gas on the outside of the tank. It goes on the INSIDE. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Mueller |
Apr 5 2006, 12:56 PM
did the powder coaters hesitat coating the tank?? |
spunone |
Apr 5 2006, 01:06 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
If your cap is like mine hit it with a buffing wheel even though it's just steel it polishes real nice then clear coat almost looks like chrome (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Qarl |
Apr 5 2006, 01:55 PM
They weren't sure how recently "empty" of gas it was and they tried to look inside, but it was a bit dark. So I gave them my lighter so they could get a better look. {BOOM!} Actually, I told them I had cleaned it thoroughly with Marine Clean and let it dry (opened) in the sun for a few hours to evaporate. And then for a few days in the garage. It had no smell of gas, so they didn't care. |
Lo-Fi Version | Time is now: 6th June 2024 - 03:16 AM |
