finishing up loose ends, it comes to a close...finally |
DanT |
Apr 7 2006, 07:52 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Finally getting it all together.
alignment is finished. -2 front and -2.75 rear. ride hieght looks very good (read low) and the front trunk is finished. Fuel pump mounted, and lines hooked up Oil cooler is functional now, nicely mounted and all lines neatly tucked away. Attached image(s) |
DanT |
Apr 7 2006, 07:53 PM
and
Attached image(s) |
DanT |
Apr 7 2006, 07:54 PM
trunk
Attached image(s) |
Demick |
Apr 7 2006, 08:16 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Hey Dan
Your car looks SOOOOOO good! You going to bring it out to the GGR AutoX in 2 weeks? I plan on being there. I just have to get my new Hoosiers mounted before that and I'm ready. New transmission (again!) since last year. I broke a ring gear tooth. Demick |
DanT |
Apr 7 2006, 08:25 PM
Hadn't thought about it Demick....Maybe ...depends on the weather for BW on the 15th...if it rains the car stays home and I go to instruct only. If that happens then I probably should go to AX #2 for a little test and tune. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Before TT #2 at TH.
I still have a few little items to attend to, nothing that really effects the operation of the car, just some items I want to have a certain way (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Type A for life I guess. |
Lo-Fi Version | Time is now: 6th June 2024 - 09:35 PM |
