Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
huge thanks to brad/clayton/kevin/joer
well, brad rocks (we knew that) everyone said when you remove the choke/fuel enrichment circuit, you pull the 2 little springed psitons inside... WRONG. there are like 15 types of IDF's, and if yours came with chokes, all the choke passages are drilled..... i need this part badly! my car was a fuel pump.... must have been 1:1 AFR....... oil change here we come..... I NEED THIS PART BY SATURDAY !!! PLEASE HELP! ANYONE HAVE PARTS CARBS???? I Mostly just need the "spring clip" at the top, but will take it all if you got it. Aaron Cox acox914@comcast.net Attached thumbnail(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I have it.
Show me the exact part. Or tell me the number... Or better yet, take a pic. Rich |
Aaron Cox |
i really need at least 1 #61....
and the springs...... under them |
r_towle |
I have two parts 44 IDF Carbs...
Is it the same part? If so, its there...I will go check... Meanwhile..think about this.. My tranny.. (In PM) I need to put a stock fifth in there... Look at the gears again and tell me what my shifting will look like...4th-5th...I mean to ask,,,is it doable... I will go out and look now.. Rich |
Aaron Cox |
compyter hard drive got erased by boneheads at bsetbuy....
im trying to find all the files (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ill post a thread... |
morph |
quality parts builder ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest ![]() |
sorry i never got back to you been real busy
i got the parts you need a can go out mon pm me if ya still need em james |
r_towle |
I got nothing...and its really cold out.
I looked, no part there... My carbs where empty, and the parts box does not have that part...sorry... Rich |
Aaron Cox |
yours werent drilled for them then.... (same assumption i made) THANKS for looking tho!!! rich - im tryin to find someone i emailed the gear files too,,,, AA morph, PMsent |
r_towle |
If you are trying to stop the flow...try jbweld...
Rich |
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
Wow man, I'm really sorry about this aaron. I know I told you this. I searched my carbs up and down witha flashlight and couldnt find any passage holes from the choke bowl...
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Aaron Cox |
hey no prob- you didnt know, neither did i, neither did clayton...scott, etc i called and checked with 8 other people.... they all said "pull em" brad said nope! if yours were drilled and arrived with a choke - you need em..... so does bob tomlinson manual... right bank has an OEL problem now. burning oil ((IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ) take your guess...im hoping for C! A ) broke a ring, needs rings B ) needs balve guides C ) from running so rich, we could have washed all the oil off the cylinder walls. hello honing. lots of gas in the oil, needs to be drained and we will go from there (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) it was the only thing that changed from when i drove in, and when i drove out. took us 30 hours to figger it out (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
MattR |
Good thing the rings were seated......
Aaron Cox |
oh, and the thing really doesnt have anything to do with the bowls. it bleeds off extra air to atmospere, air taht would be going into your engine, thus richening up the mixture, thus used for cold star enrichment (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
craig downs |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California ![]() |
Hey Aaron
I got some 40 IDF around that have the things you need . I can drop them off tomorrow |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
interesting aaron. is there no way to undo the passageways that i presume have been opened up?
k |
Aaron Cox |
I would only accept them if these were junk carbs... why take a set outta comission to make another work? if thats the case.... you sure it has them inside? snap a quick pick to be sure? if so - taht would be excellent! i can cancel my paypal to morph it his works out. thanks craig! AA |
Aaron Cox |
plug them, or leave the pistons in..... |
rhodyguy |
can you post some pictures of 54 thru 61? i've only seen the assem while attached. the back side specificly.
k |
rhodyguy |
plugs=cover plates and pistons=leave the assem in place i guess.
k |
Aaron Cox |
i can snap some pics later...... tomlinson says, pull the mechanism (big part 54 (55 is an airintake screen)) and leave the arts 57-61 alone! just put a block off plate in palce of 54.... |
Lo-Fi Version | Time is now: 4th July 2025 - 11:04 AM |
