need tech help |
need tech help |
nycchef |
Apr 15 2006, 06:16 AM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
picked up a 73 1.8 last night. drove it 55 miles on the hiway 1/2 of it fine. then it wouldn't go up past 4000rpm without stuttering almost to a stall. finally died in my driveway . woun't start up now. hasn't been run since last season according to old owner except startin once a week. stand up guy i trust him. car is almost perfect except this one (hopefully small) problem. any ideas?
Verruckt |
Apr 15 2006, 06:17 AM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
picked up a 73 1.8 last night. drove it 55 miles on the hiway 1/2 of it fine. then it wouldn't go up past 4000rpm without stuttering almost to a stall. finally died in my driveway . woun't start up now. hasn't been run since last season according to old owner except startin once a week. stand up guy i trust him. car is almost perfect except this one (hopefully small) problem. any ideas? crap in the fuel line maybe? |
MecGen |
Apr 15 2006, 06:30 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hello and Welcome !
First thing is to find if its fuel related or Spark related, I don't know how mechanicly inclined you are, but lots of members can and will walk you thru it. Need a couple details. 1.8l correct? stock injection or carbs? Let us know. Later (IMG:style_emoticons/default/beerchug.gif) |
rhodyguy |
Apr 15 2006, 09:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
is the same tank of fuel in the car from last spring? falls on it's nose at high rpm...other than the fuel question, this first thing i'd suspect is the fuel filter.
k |
DNHunt |
Apr 15 2006, 10:29 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Probably crap in the gas. As Kevin said take a look at the filter. Also try to look in the tank (not all that easy). There shoud be a sock on the oulet that does a preliminary filtering. If theres a bunch of rust in there and the fuel got low it probably sucked a bunch of crap up against the sock and into the filter. If the fuel supply is OK then you probly need to start a systematic sequence to troble shoot. Fuel supply is 1st on the list
Dave |
firstknight13 |
Apr 15 2006, 09:56 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
crap in the tank i had the same problem easy to fix remove and flush out then replace all the fuel filters!!!!
ClayPerrine |
Apr 15 2006, 10:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Open the engine compartment and remove the engine lid. Find the small 4mm bolt inserted into the fuel pressure tap on the LH metal fuel line between the injectors (note: this may have been moved to the other side by a previous owner). With the key off, remove the bolt, and install a presssure gauge onto the fitting. Tape the gauge in the middle of the back window where you can see it in the mirror, then take the car for a drive. When it starts to stumble, take a look at the fuel pressure gauge in your rear view mirror. A really big gauge makes for easy reading when looking in the mirror.
A 1.8L with the original L-Jet should have 28 psi at idle, and 32 to 34 when the engine is under load (meaing accellerating). If it gets below 28, you have a fuel feed problem. I would check the screen in the tank, the pump and the fuel filter. If someone before you had the same problem and removed the screen in the tank, what gummed up the screen in the past is now gumming up the pump. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:38 AM |
