proto31 |
Member ![]() ![]() Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None ![]() ![]() |
Is it possible to use a 23mm master cylinder on a stock 914/6 without having to make any modifications. Will it just bold in? Is this overkill? I need to replace the original 19mm and was thinking that it might make for a nice upgrade? (IMG:style_emoticons/default/sad.gif)
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
do some searching here. unless you have MONGO 4 piston brakes everywhere or just want a NO MOVEMENT pedal, it is overkill. a 19mm with stock or late model 2 piston calipers is sufficient
requires a new pushrod IIRC |
proto31 |
Thanks Aaron!
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,534 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I have a 23mm master cylinder on my car, and even with 4 pistion 944 turbo calipers all the way around the pedal is high and hard.
I may go back to a 19mm to make it have more pedal travel (better feel). If you are running stock brakes, the 19 will be fine. |
Lo-Fi Version | Time is now: 15th June 2024 - 02:08 PM |
