Source for fuel line & brake line "T" in the Seattle are |
Eddie914 |
Apr 20 2006, 09:16 AM
Unregistered |
Does anyone have a source for OEM type fabric covered fuel line (8mm & 10mm?) in the Seattle area?
I'm not happy with the 5/16" and 3/8" fuel line available at the local FLAPS. I'm also in need of a brake line "T" in order to do away with the rear brake proportioning valve. Bugmasters? Autosport? ??? Thanks Eddie ps: This is what the return fuel line looked like just below the fuel tank. (IMG:http://i38.photobucket.com/albums/e143/AlkiBMW/IMG_5096Medium.jpg) When I cleaned out the tank when I first got the 914/6, there was what appeared to be sandblasting media in the bottom of the tank. I flushed and cleaned the supply line but didn't bother with the return line since the car is equiped with Webers. The OEM lines are being replaced with Chris Foley SS lines. |
Allan |
Apr 20 2006, 09:43 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I think you can get both at a bug shop...
Series9 |
Apr 20 2006, 09:53 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Yes, any aircooled bug shop will have the T. Don't use fuel line for the supply hoses. The brake fluid will eat 'em.
reverie |
Apr 20 2006, 12:09 PM
Senior Member Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None |
Autosport should have those. Gives you a reason to say hi to Paula, too.. (IMG:style_emoticons/default/wink.gif) |
914werke |
Apr 20 2006, 01:36 PM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Autosport should have those. Gives you a reason to say hi to Paula, too.. (IMG:style_emoticons/default/wink.gif) Eddie Bow-Wow on Lake City Way will have it all. They are also up in Lynnwood. R. |
TeamAxisRacing |
Apr 20 2006, 01:59 PM
Member Group: Members Posts: 107 Joined: 13-September 03 From: seattle, Wa Member No.: 1,153 |
akers? i got some vacuum line from them the other day, they had a bunch of spools of line that sure looked like fuel line
(IMG:style_emoticons/default/jsharp.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 10:59 AM |
