Oil Cooler Bracket, sloppy workmanship or ??? |
Slowpoke |
Sep 19 2003, 09:30 AM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
On most if not all of the rebuilt engines I have looked at, they do not have the oil cooler bracket that holds the end of the stock cooler and bolts to the fan shroud. Is there a good reason for this or is it just sloppy workmanship?? I realize it is remove to hang the A/C compressor on, but why is it left off on stock rebuilds. (IMG:style_emoticons/default/confused24.gif)
Thanks Peter |
JWest |
Sep 19 2003, 09:35 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
The lousy Ford mechanic coudn't figure out where it went!
Brad Roberts |
Sep 19 2003, 11:21 AM
They lose the brackets.. then they wonder why the oil cooler seals leak "I just replaced them".
No good reason why they leave them off. Sloppy is probably a good answer. B |
Lo-Fi Version | Time is now: 28th May 2024 - 07:41 PM |
