VW to 914 Parts interchange, Parts for VW that you can use on your 914 to save $$$ |
Tobra |
Apr 28 2006, 02:49 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Seen a few people mention this, and really hit home when I bought a new gas cap for $12; okay here goes
Flasher Relay for 1968-'70 VW fits 914 $10 Fuse Box Cover for 1972-'79 Super Beetle, numbers 1-12 instead of pics $7 Gas cap for 1961-1967 Bug or Ghia fits perfect on a 914 $12 Interior light assembly for Beetle and Super sedan 1968 on $10 Window Cranks Chrome and Black from '67-'69 bug $20 Window Crank, black plastic cover $6 There are lots more, but I have to go to work, will add more later |
Mueller |
Apr 28 2006, 03:16 PM
does the flasher work exactly like the original unit??
i've tried the cheaper one and my lights flashed funky.... |
SirAndy |
Apr 28 2006, 04:59 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the rubber seal between the engine tin and the j-tubes has a VW part number ...
(IMG:style_emoticons/default/smile.gif) Andy |
Mark Henry |
Apr 28 2006, 05:54 PM
I've said this many a time....
If the part number starts with 111 or 113 or 131 or 141 or 021 etc it is a standard VW part If the part number starts with 914 its a 914 only part as are some 901 parts, but some 901 parts (not all) interchange with the 911. |
bondo |
Apr 28 2006, 06:00 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Those funky bulb holders for the gauges are used in 60s bugs. Easy to find at pick-n-pull. |
Tobra |
Apr 28 2006, 06:23 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 03:27 AM |
