How much are limited slip differentials? |
grantsfo |
Apr 30 2006, 02:55 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Curious how much are limited slip diffs and where can one find one? Does it require dropping of tranny to install one?
d914 |
Apr 30 2006, 03:21 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
$1500..!!
rick 918-S |
Apr 30 2006, 03:24 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
KenH |
Apr 30 2006, 03:28 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
$1000 - $1800 low end if you are lucky.
Tranny comes out, LSD is fitted to your Ring. Then the Pinon to Ring gear backlash has to be set & the Side Cover Pre-load has to be set. The backlash and pre-load require placing the proper shims behind the Diff Bearings. Unless you use a set of old bearings that have been opened up to just fit the shaft - the bearings have to be removed with a puller and pressed back on each time a shim is changed. Ken |
Joe Bob |
Apr 30 2006, 03:40 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
last I checked...GPR had the Quaife for 1250. There's not much markup on them....Factory ones are a bit more.
Aaron Cox |
Apr 30 2006, 03:41 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
$1000 - $1800 low end if you are lucky. Tranny comes out, LSD is fitted to your Ring. Then the Pinon to Ring gear backlash has to be set & the Side Cover Pre-load has to be set. The backlash and pre-load require placing the proper shims behind the Diff Bearings. Unless you use a set of old bearings that have been opened up to just fit the shaft - the bearings have to be removed with a puller and pressed back on each time a shim is changed. Ken i think i called carquip and its about 500 bucks to set up the ring grar backlash and shimming of the diff.... so about 2 G installed... |
balljoint |
Apr 30 2006, 05:13 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
That price isn't too far off getting an LSD for a truck installed.
Aaron Cox |
Apr 30 2006, 05:32 PM
KenH |
Apr 30 2006, 05:37 PM
[/quote]
i think i called carquip and its about 500 bucks to set up the ring grar backlash and shimming of the diff.... [/quote] Plus shipping the tranny (both ways) to CO. Ken |
Aaron Cox |
Apr 30 2006, 05:42 PM
[quote name='KenH' date='Apr 30 2006, 04:37 PM' post='671565']
[/quote] i think i called carquip and its about 500 bucks to set up the ring grar backlash and shimming of the diff.... [/quote] Plus shipping the tranny (both ways) to CO. Ken [/quote] thats another 150...... ken - dodnt you get one installed recently? |
KenH |
Apr 30 2006, 06:04 PM
Installed it myself.
Its not hard, just takes time. Helps if you take the Jerry Woods transmission class. (he knows 101 tricks to make things simple) If anybody is interested I would be glad to help. Ken |
hmeeder |
Apr 30 2006, 06:53 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
Stock 901 LSDs are pricing at just under 5 Gs. (at least at Pelican and AA.)
Quaife are definitely the best price alternative and as I understand them, they do not have the added cost of worn disks to replace somewhere way down the road. |
Aaron Cox |
Apr 30 2006, 06:54 PM
Stock 901 LSDs are pricing at just under 5 Gs. (at least at Pelican and AA.) Quaife are definitely the best price alternative and as I understand them, they do not have the added cost of worn disks to replace somewhere way down the road. i remeber paul guard has his own line of torsen style IIRC... there are Guard, ZF's and Quaifes IIRC...... |
rickyhgarcia |
Apr 30 2006, 06:57 PM
UPS truck is here... Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 |
I paid about $1400.00 plus shipping for a 40% Guard Transmission LSD. I bought it directly from Guard.
KenH |
Apr 30 2006, 07:49 PM
Remember you can convert a 915 Fine Spline LSD to the 901 Coarse Splines with some Guard Transmission parts. LSD carriers are all the same.
Ken |
Aaron Cox |
Apr 30 2006, 07:52 PM
KenH |
Apr 30 2006, 07:56 PM
Yes - buy them from your Porsche dealer.
Ken |
grantsfo |
Apr 30 2006, 08:24 PM
So this sounds like a good project to include with close ratio transmission build at the end of this year. Appreciate the info.
This is the first 914 I have owned that has enough power to need an LSD. Very cool! |
nine14cats |
Apr 30 2006, 10:29 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Hi Grant,
I've heard alot of folks who dual drive LSD's in AX and Track go for the 40% versus the 80%. That being said, I installed an 80% unit in my 901 for $1400 from Paul Guard. I had a shop do it. I can't remember the install price but I know I got a good deal. Since I was more track oriented, I decided on the 80%. But I didn't seem to have a problem with the push in the car from the LSD. I'd just tap the gas pedal! Bill P. |
brant |
Apr 30 2006, 11:37 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Definitely a thing to do while your inside the box for other reasons...
(or vica versa) Interestingly... I had a discussion with a quaife dealer last week. He said EXACTLY the same thing that Paul Guard admitted to me. For a 911 the zf style is recommended track and the Torque Bias for Autox... Buttttt..... both the dealer and Paul himself admitted that this isn't absolutely true for a mid engined car. The Torque biasing can out perform the clutch-pack on the TRACK in a 50/50 balanced mid-engined car. so do your reasearch before you drop that cash next winter. brant |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:20 AM |
