Fuel pump mounts, Cheaper source for anti-vibration mounts? |
MrKona |
Jun 3 2006, 11:56 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Has anyone found a cheaper source for the fuel pump rubber anti-vibration mounts? The porsche OEM mounts are something like $27.95 each. (IMG:style_emoticons/default/bs.gif)
I've found multiple suppliers on the web, but they cater to bulk buyers. Anyone found a cheaper source that sells just two? |
MrKona |
Jun 4 2006, 12:08 AM
Has anyone found a cheaper source for the fuel pump rubber anti-vibration mounts? The porsche OEM mounts are something like $27.95 each. (IMG:style_emoticons/default/bs.gif) I've found multiple suppliers on the web, but they cater to bulk buyers. Anyone found a cheaper source that sells just two? Okay, found a source: https://sdp-si.com/eStore/ Lot's of mounts same type as Porsche, just have to wonder which ones are closests to Porsche OEM. |
MrKona |
Jun 4 2006, 12:20 AM
Has anyone found a cheaper source for the fuel pump rubber anti-vibration mounts? The porsche OEM mounts are something like $27.95 each. (IMG:style_emoticons/default/bs.gif) I've found multiple suppliers on the web, but they cater to bulk buyers. Anyone found a cheaper source that sells just two? Okay, found a source: https://sdp-si.com/eStore/ Lot's of mounts same type as Porsche, just have to wonder which ones are closests to Porsche OEM. Okay, last time replying to myself. http://www.mcmaster.com/ also has alot. Should of thought of them in the first place. Can any of you technical types out there provide some guidance on which replacement mount might be most appropriate? (Shear, compression force, rubber, urethane... etc...) |
GeorgeRud |
Jun 4 2006, 09:48 AM
Mcmaster.com is great. As far as sizing, just get the basic diameter and height you need. There is very little weight associated with the fuel pump, so any of the rubber mounts of the correct diameter will be more than strong enough.
I've found many little pieces like clutch clevises, 7mm nuts, and the like at McMaster-Carr when no one else seems to have them. Great company to work with and they will accept small orders as well as big industrial orders. Their printed catalog is clurrently 3592 pages thick, if they don't have it, it probably ism't made anymore! |
Gint |
Jun 4 2006, 10:56 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Okay, last time replying to myself. http://www.mcmaster.com/ also has alot. Should of thought of them in the first place. Can any of you technical types out there provide some guidance on which replacement mount might be most appropriate? (Shear, compression force, rubber, urethane... etc...) Hey, look at it this way. You answered your own question, beat the rest of us in doing so, and you helped everyone else that had the same question. Thanks! I need a set. |
jd74914 |
Jun 4 2006, 11:00 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I just took thick piece of rubber and drilled through it and then put a bolt in. It seems to be insulted well enough; there isn't any rattling and the pump is on very securely.
Lo-Fi Version | Time is now: 1st June 2024 - 07:51 AM |
