HarborFreight scissor lift - any experience? |
Aaron Cox |
Jun 5 2006, 08:48 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
ive used the snapon equivalent, and it makes stuff really easy. to get a car up on it tho might require 2x6's as ramps......
any one have any experience with these? cheap enuff, and should last forever at the rate i use it.... (IMG:http://www.harborfreight.com/cpi/photos/39800-39899/39894.gif) http://www.harborfreight.com/cpi/ctaf/disp...temnumber=46604 |
96conv |
Jun 5 2006, 09:29 PM
Can't reMember Group: Members Posts: 82 Joined: 16-March 04 From: Solano County Member No.: 1,807 |
Aaron Cox |
Jun 5 2006, 09:42 PM
thanks for the link! seeing if pops will go halves on it... |
96conv |
Jun 5 2006, 09:47 PM
You're quite welcome!
Joe Bob |
Jun 5 2006, 09:50 PM
Unregistered |
HF....lifting my pride and joy....working under it....HF.....hmmmm, not MY idea of a good time.....
For double the price, I got a 4 post lift installed.... |
Jeroen |
Jun 6 2006, 05:44 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
It's been on my wish-list for quite some time already
But there's always something else that I need more urgently Agreed that it's not as good as a 2 post lift, but I don't have room for one of those in my garage anyway |
URY914 |
Jun 6 2006, 06:22 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
HF?
Do you want trust your life to something a 10 year old in China built? (IMG:style_emoticons/default/confused24.gif) |
bd1308 |
Jun 6 2006, 06:27 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I bet that 10 year old put a lot of work into it, ya know?
b |
maf914 |
Jun 6 2006, 07:21 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Last year Car & Driver magazine had an article about die-cast model car production in China. Pretty interesting. It seems that a majority of these models now come from China. (IMG:style_emoticons/default/idea.gif)
Along with Harbour Freights tools. (IMG:style_emoticons/default/laugh.gif) |
Aaron Cox |
Jun 6 2006, 10:14 AM
they have a good rep over at pelican......
and they have lock features..... |
andys |
Jun 6 2006, 10:35 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Don't forget too that Harbor Freight is liable, so it's unlikely it's that much of a POS. They are a fairly sizeable company, and I suspect some form of certification/testing is required by them by their vendors for potentially dangerous equipment.
Andys |
TROJANMAN |
Jun 6 2006, 10:38 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
very cool
wish i hadn't just bought a car hauler, cause i'd be buying one of those |
Mueller |
Jun 6 2006, 11:04 AM
QUOTE HF? Do you want trust your life to something a 10 year old in China built? I guess one could always make 39" tall jackstands for a little bit more support (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/welder.gif) |
GWN7 |
Jun 6 2006, 11:29 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
they already make extra tall stands.....
http://www.tooltopia.com/index.asp?PageAct...ROD&ProdID=9086 |
smontanaro |
Jun 6 2006, 11:54 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Hmmm... Those Astro Pneumantic stands have a minimum height of 56". I don't think the HF lift goes that high. (I presume there are other mid-height stands somewhere though.)
Skip |
ThinAir |
Jun 6 2006, 12:09 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Starting height on the lift is 15-3/4" Isn't that taller than the bottom of most 914s?
Edit - Nevermind! It says the minimum height is 3-7/8". So then what does "starting lift height" mean? |
Aaron Cox |
Jun 6 2006, 12:13 PM
Starting height on the lift is 15-3/4" Isn't that taller than the bottom of most 914s? Edit - Nevermind! It says the minimum height is 3-7/8". So then what does "starting lift height" mean? not sure what that means... but QUOTE Minimum height: 3-7/8'' and the pelican guys just drive up on 2x10's to sit their 911's on it |
TROJANMAN |
Jun 6 2006, 01:00 PM
Starting height on the lift is 15-3/4" Isn't that taller than the bottom of most 914s? Edit - Nevermind! It says the minimum height is 3-7/8". So then what does "starting lift height" mean? probably the first lift lock position. (IMG:style_emoticons/default/idea.gif) |
Aaron Cox |
Jun 6 2006, 01:06 PM
sounds logical (IMG:style_emoticons/default/smile.gif)
TROJANMAN |
Jun 6 2006, 01:19 PM
colage ejakated
Lo-Fi Version | Time is now: 7th June 2024 - 08:14 AM |
