Dry oil sump tank for 914-6 |
jvirn |
Jun 6 2006, 11:45 AM
Newbie Group: Members Posts: 3 Joined: 31-May 06 From: LaFayette, NY Member No.: 6,111 |
Anyone install a dry sump tank up front instead of the factory type? Thinking this may be less exspensive & more readily available?
Aaron Cox |
Jun 6 2006, 11:46 AM
yes. many people.
do a search for "peterson oik tank" here... |
Brad Roberts |
Jun 6 2006, 12:09 PM
90% of the serious race cars run a front mounted dry sump tank. You have to be careful about which one you buy. Some of them are not vented correctly for the 911 engines.
B |
jvirn |
Jun 6 2006, 12:47 PM
That's what I was looking at. Something similar to the Peterson tanks, about 9-10 quarts & possibly replacing the engine mounted cooler with a larger radiator up front.
brant |
Jun 6 2006, 01:36 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
possibly replacing the engine mounted cooler with a larger radiator up front. many people use a front and the original oil cooler both. some pro-level race engines block it off... and big motors (3.6) don't have the motor cooler... but more coolers can be better I personally run the engine cooler and 2 front coolers all at the same time brant |
Lo-Fi Version | Time is now: 9th June 2024 - 01:37 PM |
