> Tons of /4 rocker arm Questions......, stock /4 ratio, variance between sets...
Mueller
post Sep 30 2003, 09:37 AM
914 Freak!
I was going to use the Pauter roller rocker arms
(ratio of 1.5:1) but decided to sell them since the money in my pocket would be better right now than the money in my motor (IMG:style_emoticons/default/smile.gif)
1)I thought I read that the stock /4 arm are supposed to be 1.3:1..is this correct?
2)How often are they the correct ratio?
3)What is the biggest difference has anyone seen?
4)Would the /4 benifit from using different ratio arms on the intake and exhaust (example: stock ratio on intake, 1.5 ratio on exhaust)?
5)What improvements can be made to the stock arms?
6)Is there an interest in modified/blueprinted stock arms?
7)Is there an interest in non-stock ratio stock type arms?
8)Pauter already offers 1.5:1 aluminum arms, but is there a market for different ratio aluminum arms?
Replies(1 - 7)
Charles Deutsch
post Sep 30 2003, 10:07 AM
Unregistered
DD has said in the past that he read somewhere that the rocker arm ratio was 1.3:1. Couldn't this be measured directly on the stock arm? Where did you buy the Pauter roller rocker arms? Is there a place on the web that sells them?
Charles Deutsch
post Sep 30 2003, 10:15 AM
Unregistered
I just visited the Pauter web site and realized that they already do something that I thought would be a good idea for an aircooled flat-four motor : "... tremendously strong foundation provided by the one-piece block ".
Mark Henry
post Sep 30 2003, 10:41 AM
that's what I do!
3/ VW was good at getting the ratio correct
4/ 2 different ratio's would need a custom cam, not worth it IMHO.
5/ You can lighten them a bit and if your anal you can balance them all the same.
6/ little, see above
7&8/ you must have cams made for different ratio's, forged Cr-Mo would be much better, I'm not crazy about aluminum rockers and rollers have the heavy part right where you don't want it, over the valve.
Mark Henry
post Sep 30 2003, 10:45 AM
that's what I do!
QUOTE(Charles Deutsch @ Sep 30 2003, 08:15 AM)
Pauter big block is for drag racing only.
john rogers
post Sep 30 2003, 11:17 AM
Hopefully this will help some:
- Yes they are
- Pretty close most all the time
- We have checked probably 2 dozen and they were right on.
- A different cam ggrind would be needed
- Use 911 or Pinto adjusters
- Hummm, probably not much
- Humm probably not
- Pauter's are 1.48:1 and are generally used with a cam that has a much smaller base circle and the gring made to reduce the ramp up when the lifter starts up the lobe so the load on the valve train is slightly less. The cam has to ground to use these or there will be interference problems with the pistons. We used them in my stroker four and even switached back to stock rockers for a while and figured we lost 20 to 25HP as the total lift of the cam was reduced. The engine was less responsive too. Pauter and Auto craft are about the only ones doing this stiff and usually it is for drag motors or low RPM off road engines.
Charles Deutsch
post Sep 30 2003, 12:58 PM
Unregistered
QUOTE(Mark Henry @ Sep 30 2003, 08:45 AM)
Yes, I know. It's just that with the reciprocating mass of the pistons, I feel that the crank should be anchored in a solid mass rather than a bolted-together case. Just a feeling I got everytime I thought about it ... obviously, I have no hard numbers.
redshift
post Sep 30 2003, 01:12 PM
Bless the Hell out of you!
QUOTE(Charles Deutsch @ Sep 30 2003, 12:15 PM)
But unstreetable.
(IMG:style_emoticons/default/sad.gif)
M
- Lo-Fi Version Time is now: 15th July 2025 - 01:12 AM
