for shipping purposes, what is the weight of a completly dress 914-6 engine |
freezing14 |
Jun 14 2006, 09:37 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
need this info for new acquisition
dimitri |
Jun 14 2006, 12:53 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
According to Porsche specification booklet, the engine weight is 180kg. Dimitri
lapuwali |
Jun 14 2006, 12:58 PM
A stock 2.0 914-6 engine, or a later 911 engine? The Sixes don't all weigh the same.
freezing14 |
Jun 14 2006, 01:22 PM
it is a original 914-6 engine with everything ( tin carbs, flywheel, alt) but the exhaust
dimitri |
Jun 14 2006, 06:02 PM
180kg, about 400 lb is close enough. If you look at the difference between 2.0 L
and 3.0, the biggest one is the case material, magnesium against al, but than you have cast iron sleeves against al, bigger piston/ shorter connecting rod, smaller mains. Carbs or Cis probably not much weight difference. Dimitri |
Lo-Fi Version | Time is now: 10th June 2024 - 01:05 PM |
