Now it's the #$%#@%^#% transmission, Am I dreaming? |
BigDBass |
Jun 16 2006, 09:23 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
After 26 days dealing with the brakes etc, I finally go for a drive with my wife.
Car's running great. Beautiful night, Herbie Hancock competing with the revving 2.0... Then all of a sudden, shifting goes to hell. Grinds nastily into first, have to muscle into 2nd 3rd etc with a surprising amount of force. By the time I got closer to home, I could barely get the car in gear at all. So um, help... |
Joe Bob |
Jun 16 2006, 09:34 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Cone screw(s) loose in the shifter rod?
Dave-O |
Jun 16 2006, 09:35 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Good news! It's not the transmission.
Sounds like you have to adjust the clutch cable. These do require periodic adjustment on 914's. Pull back on your clutch cable and see how much free play there is on it. If it is more than 1" it is too much (in my opinion). To adjust crawl under the car. Look on the passenger side of the transmission. You will see a cable wrap around a pulley. On the end of the cable there are two jam nuts. "Unjam" the nuts using two 11mm wrenches. Then tighten them until you have the slack in the pedal that you are looking for. You will be able to feel in the throw of the pedal that the clutch is fully dissengaging. Go for a drive and try it out. Give me a call if you need a better explanation 9203196954 |
So.Cal.914 |
Jun 16 2006, 10:29 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Good news! It's not the transmission. Sounds like you have to adjust the clutch cable. These do require periodic adjustment on 914's. Pull back on your clutch cable and see how much free play there is on it. If it is more than 1" it is too much (in my opinion). To adjust crawl under the car. Look on the passenger side of the transmission. You will see a cable wrap around a pulley. On the end of the cable there are two jam nuts. "Unjam" the nuts using two 11mm wrenches. Then tighten them until you have the slack in the pedal that you are looking for. You will be able to feel in the throw of the pedal that the clutch is fully dissengaging. Go for a drive and try it out. Give me a call if you need a better explanation 9203196954 I agree, this is such a common thing that the tool kit in mine has a small pair of vise grips I use just for adjustment. I'll let you in on a little secret for emergency adjustments. If it is going out of adjustment, pull to the curb and find an egress (driveway entrance) put front tire on curb line and drive forward keeping tire on curb. Car will raise up on passenger side enough for you to get under and adjust clutch. Just don't touch exaust. |
elwood-914 |
Jun 16 2006, 10:32 PM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
Mine only had one nut. It kept loosening up and I had to readjust it again. Bought another nut to "double nut" it and never had a problem since.
Tim |
SGB |
Jun 16 2006, 10:59 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
If it isn't the clutch cable, or the cone screw (my first two guesses), next would be the shift linkage bushing at the firewall. Mine disentigrated all at once about a year ago. Suddenly sometimes the shifter just would NOT go into the slot.
BigDBass |
Jun 16 2006, 11:06 PM
Hey,
Crisis averted. It was the clutch cable adjustment. In fact, it now shifts better than ever. Dave-O graciously ran through it on the phone. He is pulling ahead on my list of 914 heros. So now I know how to adjust the clutch cable. I can't wait to have more interesting questions. Does it mean anything that I could've done it by hand? The nuts are still lose enough that I can tighten both down by just turning the locking one with my fingers. Sweet, this is my new record for shortest downtime (IMG:style_emoticons/default/biggrin.gif) Thanks all for chiming in. Joining the 914 caravan to the WI gathering in 8 hours. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:32 PM |
