> Grease cap installation, ...this seems too hard...
jrmole
post Jun 18 2006, 10:17 AM
Torque is cool!
Hi all,
I've just finished putting new front rotors & bearings on my car. Haynes tells me to install the grease cap with a "soft faced hammer". OK - but should I really need to hit it dozens of times with all my might only to have it pop back off? These were really hard to remove in the first place, so I am suspecting more British understated humor.
My next option is the torch and the gloves to try to heat it up enough to slip onto the rotor. Of course, if I do that, I will never get it off again.
Help!
Replies(1 - 7)
Sk8erBri
post Jun 18 2006, 10:21 AM
i hope some one replys as i have my car on blocks now ans will be getting to those front caps soon, how did you get them off? just pry wiht a screw driver?
dinomium
post Jun 18 2006, 10:23 AM
Git on a chair son, all the good stuff is goin over yer head!
I had to grease up the ring of the cap and then use the bfh, using the soft faced hammer caused the cap fly off and hit me in the nutz! (IMG:style_emoticons/default/blink.gif)
I hate it when that happens!
jrmole
post Jun 18 2006, 01:15 PM
Torque is cool!
QUOTE(Sk8erBri @ Jun 18 2006, 09:21 AM) *
It has been a few months for me as I opened a can of worms (new tie-rods, new brake lines, might as well do the master cylinder while I am in here, etc.). I think I ended up using a pair of vise-grips and a big honking screwdriver and a lot of elbow grease.
Lot of luck.
LowGT
post Jun 18 2006, 07:19 PM
1.8 and Proud!
I never really have problems with them. Just like anything round, pry a little with a screw driver, turn wheel a little, pry a little, turn a little, etc.. and eventually it pops out with getting damaged.
Same for install, hold it on and tap it so it sticks on there. Then tap it with a rubber mallet while turning the wheel until it fully seats. You always want to remove and install evenly so it doesn't bend out-of-round. Once it's bent, it will be a PITA to remove/install it for eternity.
jrmole
post Jun 18 2006, 07:44 PM
Torque is cool!
QUOTE(LowGT @ Jun 18 2006, 06:19 PM) *
Then I suspect that a previous owner trashed them. It took an incredible amount of force to make them come off. Having never done it with clean caps, I guess I got the lesson without knowing it. I'll check the roundness with my calipers next weekend and see if they are flattened - if so, perhaps I can make it better.
Thanks
SGB
post Jun 18 2006, 08:18 PM
just visiting
Maybe there is so much grease that it seals up so that when you are bangin 'em on it builds up pressure...
jrmole
post Jun 18 2006, 10:00 PM
Torque is cool!
QUOTE(SGB @ Jun 18 2006, 07:18 PM) *
I've got just a skim coat on the inside of the cap to try to help is slide on - literally as little as I could put on and tell it was there. If that keeps the cap from going on, then the tolerances on this part are amazing.
Good idea, though. Before I pull out the REALLY BIG HAMMER ™, I will clean the grease off entirely and try again.
- Lo-Fi Version Time is now: 16th June 2024 - 09:09 PM
