DOT5. What does it do to regular brake seals, etc?, Do you need anything special to use it? |
RoadGlue |
Jul 7 2006, 01:15 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I ask, because my recently aquired 914 has DOT 5 brake fluid, but I don't know what, if any provisions have been made to the car to use it. I know a rear caliper was recently replaced with an off the shelf used caliper with stock seals.
I'd like to go back to using Super Blue. Is a flush in order, or would I be looking at a complete brake system overhaul? Thanks! |
Dave_Darling |
Jul 7 2006, 01:34 PM
Which DOT-5 fluid? Silicone fluid, or the "DOT 5.2" (or whatever comes after the decimal) which is still glycol-based?
If you're using regular brake fluid stuff (the 5.2), just put it in and go. If you want to use silicone fluid, umm... The short version is "don't". The long version is that you will need to replace all of the rubber in the system, including all seals inside the calipers and MC, that have touched regular brake fluid. And you'll need to change them all again once you decide that silicone fluid sucks and you want to go back to regular stuff. For ATE Blue or Typ 200, just pour it in like regular fluid. --DD |
lapuwali |
Jul 7 2006, 02:02 PM
It's 5.1, not 5.2. DOT5 is silicone-based fluid. DOT5.1 is not.
I pretty much agree with Dave. Any silicone fluid in the system will react badly with non-silicone fluid, making this whitish goo that likes to ball up and block passages. You might try draining a sample from the system into a cup, and add some of your favorite fluid, to see what happens. |
RoadGlue |
Jul 7 2006, 02:40 PM
It's 5.1, not 5.2. DOT5 is silicone-based fluid. DOT5.1 is not. I pretty much agree with Dave. Any silicone fluid in the system will react badly with non-silicone fluid, making this whitish goo that likes to ball up and block passages. You might try draining a sample from the system into a cup, and add some of your favorite fluid, to see what happens. Sorry, I should have been clearer. I've been told that the car has silicone fluid in it now. I'd like to ditch that and go with ATE's 5.1 (right?) as I have two full, unopened containers sitting on my garage's floor. I'll see how the two react, good suggestion. So what do I do if they react poorly? Power flush? Thank a lot! |
lapuwali |
Jul 7 2006, 02:50 PM
If they react poorly, I'd probably just buy some silicone fluid and live with it until you decide to do a complete brake system rebuild. Be fairly careful pouring in new fluid, as one of the problems with silicone fluid is that it's great for trapping small air bubbles that are very difficult to bleed out.
RoadGlue |
Jul 7 2006, 02:57 PM
If they react poorly, I'd probably just buy some silicone fluid and live with it until you decide to do a complete brake system rebuild. Be fairly careful pouring in new fluid, as one of the problems with silicone fluid is that it's great for trapping small air bubbles that are very difficult to bleed out. Boo!!! OK. Lame. I'd hate to have to open a fresh can of ATE to find out they're not compatible. I guess I could just bleed my gf's car at that point and use some of it there. Oh well. Thanks again! |
Air_Cooled_Nut |
Jul 7 2006, 07:26 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Nuthin' wrong with the purple DOT5, got it in my '81 Goldwing and '72 VW, narry an issue!
Don't mix DOT's, I know that. VW faq on DOT 5: http://www.icbm.org/erkson/ttt/silicone.txt |
lapuwali |
Jul 7 2006, 08:20 PM
My feelings on DOT5 are skewed. Back in my evil bike days, DOT5 was considered horrible. My only experience with it at the time was in a Ducati (OEM use), which had brakes that, while very powerful, always felt mushy no matter how carefully I bled it. Most bike racers wouldn't touch the stuff.
More recently, I was surprised at how vehemently British car guys will defend it. They LOVE the stuff, mostly because it won't damage their paint when a master cylinder leaks, and doesn't soak up water to rust their cast iron brake parts even if the cars aren't used more than a few times a year. I personally won't use it, but not for any "scientific" reasons. I also don't know of many compelling reasons to use it. I do find it interesting that even makers of very expensive cars don't use it OEM (thus nullifying the extra expense angle). There are plenty of good, and often very expensive, non-silicone brake fluids with very high boiling points (way above the DOT4 levels). There are also non-silicone fluids that are much less hydroscopic than plain DOT4 (Castrol LMA, for example). |
clarkcou |
Jul 7 2006, 09:47 PM
Member Group: Members Posts: 115 Joined: 17-October 03 From: Peoria, Arizona Member No.: 1,257 Region Association: Southwest Region |
I had a 89 Fiat X1/9 and switched to DOT 5 Silicone fluid. The brakes lost the immediate, firm, and communicative feel. Always felt like some air in the line, no matter how many times I bled the system. My vote - Don't go with it.
RoadGlue |
Jul 7 2006, 09:50 PM
I had a 89 Fiat X1/9 and switched to DOT 5 Silicone fluid. The brakes lost the immediate, firm, and communicative feel. Always felt like some air in the line, no matter how many times I bled the system. My vote - Don't go with it. I'm not going with it. I already have it due to a misguided previous owner. Trying to figure out how to get rid of it. There have been some good test suggestions, and I'll give those a try when I have the chance. (IMG:style_emoticons/default/smile.gif) |
RoadGlue |
Jul 13 2006, 05:20 PM
Well, here's what happens when I mix the current brake fluid with ATE (the blue stuff on the bottom):
(IMG:http://www.sonic.net/randy/914club/brake/2.jpg) (IMG:http://www.sonic.net/randy/914club/brake/3.jpg) (IMG:http://www.sonic.net/randy/914club/brake/4.jpg) Some pictures of the two fluids after mixing (by swirling the jar for 15 seconds) (IMG:http://www.sonic.net/randy/914club/brake/5.jpg) (IMG:http://www.sonic.net/randy/914club/brake/6.jpg) The two fluids seperate again after a minute or two. So what would you do? Do you think flushing out the old stuff for ATE would be a safe bet? I'm pretty sure the old stuff is silicone based. |
lapuwali |
Jul 13 2006, 05:33 PM
I would probably take the risk myself, however, I also wonder if heat and/or pressure is required to start a reaction. I'd be careful for the first week, and plan on a total brake rebuild.
McMark |
Jul 13 2006, 05:36 PM
I think you should pump out all the super blue and fill it with Silicone DOT 5.
(IMG:style_emoticons/default/lol2.gif) Just kidding. (IMG:style_emoticons/default/biggrin.gif) Gone crazy yet Randy. (IMG:style_emoticons/default/tongue.gif) I don't have any advice (only jokes), brakes are a scary thing to mess with, but a full brake rebuild is $$$$$. (IMG:style_emoticons/default/sad.gif) |
Air_Cooled_Nut |
Jul 13 2006, 11:14 PM
Send it off to get analyzed. Tell 'em you want to know what kind of brake fluid it is.
Try this: Pour some of the brake fluid in a glass container. Place an equal amount of water into the container as well. Stir. If the water separates from the brake fluid, it's DOT-5. If it combines with the brake fluid then it's DOT-4 or less. Tell you what, I got DOT-4 and -5 in the garage, I'll go mix up a batch, take pictures, and get back to ya (IMG:style_emoticons/default/beer3.gif) |
McMark |
Jul 13 2006, 11:18 PM
Way to go Toby! (IMG:style_emoticons/default/clap56.gif)
Air_Cooled_Nut |
Jul 14 2006, 12:10 AM
I broke out two of my measuring shot glasses...of course my g/f comes walking into the kitchen at the same time, looking a little puzzled (IMG:style_emoticons/default/blink.gif)
"Yer gonna pour me something, too, right?" (IMG:style_emoticons/default/barf.gif) "No sweetie, I'm just doing some measuring in the garage." She doesn't ask any questions, just turns around and heads back into the bedroom. Whew! So, here's the materials in question. The DOT-4 goes in my Jetta, the DOT-5 in my Goldwing and Squareback (I haven't had to touch the 914 but judging from the looks of the fluid, it's DOT-3). Water, 1/2 ounce of DOT-5 and 1/2 ounce of DOT-4 |
Air_Cooled_Nut |
Jul 14 2006, 12:15 AM
How they look after adding some water:
Notice the swirly effect of the water in the DOT-4 (right shot glass). The water in the DOT-5 just sinks to the bottom (left shot glass). Note: Due to the florescent lighting in the garage, the DOT-5 looks blue; it's really a dark, pretty purple. Welcome to the world of color photography (digital or print!). |
Air_Cooled_Nut |
Jul 14 2006, 12:17 AM
Pouring more water into the DOT-5:
Pouring more water into the DOT-4: |
RoadGlue |
How they look after adding some water: Notice the swirly effect of the water in the DOT-4 (right shot glass). The water in the DOT-5 just sinks to the bottom (left shot glass). Note: Due to the florescent lighting in the garage, the DOT-5 looks blue; it's really a dark, pretty purple. Welcome to the world of color photography (digital or print!). Cool! I'll repeat this test tomorrow with what's in the car and see what happens. Thanks! |
Air_Cooled_Nut |
Jul 14 2006, 12:18 AM
How the brake fluids look after pouring water into them after a few seconds:
Lo-Fi Version | Time is now: 31st May 2024 - 06:25 PM |
