W0097671..., Bus or 914 Engine Block Serial #? |
BMartin914 |
Jul 13 2006, 09:54 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Just looked at a car here tonight for a potential new member and the owner is clueless about the engine - the whole car really, but that is beside the point.
The serial # stamped on the lower right corner of the block (on top, at a 45 degree angle) is W0097671. All the owner can say is that it is a 1.8 - or so he was told. So is it a bus engine, or a 1.8L 914 engine? |
TROJANMAN |
Jul 13 2006, 09:59 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Like the new sig line Ben.
Thanks again for looking at that car. |
BMartin914 |
Jul 13 2006, 10:01 PM
Like the new sig line Ben. Thanks again for looking at that car. Since YOU wouldn't let it go...I've decided to embrace it! (IMG:style_emoticons/default/clap56.gif) No problem. |
brant |
Jul 13 2006, 10:05 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
does the screen door help keep you warm?
how does the car look? whats the new guys name? brant |
BMartin914 |
Jul 13 2006, 10:17 PM
does the screen door help keep you warm? how does the car look? whats the new guys name? brant A guy who gets cold easily wants more ventilation......go figure (IMG:style_emoticons/default/confused24.gif) Car looks good. If the new guy passes, it might become my vintage racer project (IMG:style_emoticons/default/burnout.gif) New guy is PAUL. he was impressed with my driving skills, so now he wants to buy one. (which i owe all to you, brant) (IMG:style_emoticons/default/driving.gif) But enough with the small talk. Is it a bus engine? (IMG:style_emoticons/default/idea.gif) It has dual Webers on it. Stay on topic you hooligans...bus or 914? someone with a knowlegde of VW serial #s should be able to tell right away. The 914 info page didn't answer my question. I wouldn't say it LOOKS good. It is very soild and rust free, but the paint sucks and the color is ugly over the original yellow. Perfect for a race car project... |
TROJANMAN |
Jul 13 2006, 10:22 PM
Ben,
according to this site, it looks like it is a 1700 cc Type 4 Bus or Porsche, i am not sure (IMG:style_emoticons/default/confused24.gif) http://type2.com/bartnik/enginecodes.htm does your case have a W code on it? |
Bleyseng |
Jul 13 2006, 11:34 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
IIRC "W" code engines were in 914's and 411's. Started out as a 1.7 80hp motor but if the PO says its a 1.8l its been rebuild with 93mm pistons. Pretty common as the domed 90mm pistons were expensive compared to the 93's.
BMartin914 |
Jul 13 2006, 11:36 PM
This is interesting:
QUOTE 1.7L serial numbers always begin with the letter W, followed by a number corresponding to the year of the car. For example, a 1972 1.7L engine's serial number would start with the sequence W2. From Pelican's "How to Buy a 914" Article So it appears to be a 1.7 from 1970... This indicates that the bus cases have the # stamped behind the oil filler (which is like mine - a Gx case). |
brant |
Jul 13 2006, 11:46 PM
This is interesting: QUOTE 1.7L serial numbers always begin with the letter W, followed by a number corresponding to the year of the car. For example, a 1972 1.7L engine's serial number would start with the sequence W2. From Pelican's "How to Buy a 914" Article So it appears to be a 1.7 from 1970... This indicates that the bus cases have the # stamped behind the oil filler (which is like mine - a Gx case). and what year was the chassis... wasn't it a 1970 that you looked at? so it stands to reason that its the original case that came in the car perhaps a PO rebuilt it with bigger pistons.... and perhaps not. any signs on the motor that its ever been rebuilt? like blue or red gasket sealer, or any telltale signs? brant |
BMartin914 |
Jul 13 2006, 11:56 PM
and what year was the chassis... wasn't it a 1970 that you looked at? so it stands to reason that its the original case that came in the car perhaps a PO rebuilt it with bigger pistons.... and perhaps not. any signs on the motor that its ever been rebuilt? like blue or red gasket sealer, or any telltale signs? brant The car is a 71. Mfr. date 4/71. Engine is very clean, but the owner was under the impression that Painter's replaced the engine, but really has no clue. I didn't see any signs of gasket sealer, etc., but the engine was very down on power. Popping and backfiring. Didn't feel like a rebuild with only a couple thousand miles... The owner has had it for 8 years. It was a one owner car when he got it. Says it still had the original FI on it when he bought it. Then someone told him the motor was "dead" and he had someone acting as his agent deal with painter's who then rebuilt? replaced? the engine and slapped some Webers on it. |
Gint |
Jul 14 2006, 05:51 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I didn't see any signs of gasket sealer, etc., but the engine was very down on power. Popping and backfiring. Didn't feel like a rebuild with only a couple thousand miles... 1.7's at altitude are extremely anemic. If you're not used to driving a 1.7 (you have the 2.0 "rat" motor LOL), it will seem like a pig. And low compression 1.8 jugs may not be of much help with that. Add carbs and an FI cam on an engine that isn't timed/tuned properly and you could have a serious dog. Nice sig Ben! Add a small pic of that fleece jacket. I'm sure Greg has a copy for ya. |
davep |
Jul 14 2006, 05:58 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Give me the VIN and I'll look to see if it is a good fit to the database. Get the chassis # and paint code from the Karmann badge also please, I don't have much '71 info. It could certainly be the correct engine for the car.
SLITS |
Jul 14 2006, 06:42 AM
Ok, where's the dipstick?
If the boss on the bottom of the block (entry point for the BUS dipstick & tube) is not capped, it is a teener engine. |
BMartin914 |
Jul 14 2006, 09:23 AM
Bleyseng |
Jul 14 2006, 09:27 AM
How did the 411 dipstick work? like a teener or a bus?
davep |
Jul 14 2006, 10:20 AM
I believe the one in my 411 was the same as the 914.
Dave_Darling |
Jul 14 2006, 02:30 PM
The 411 Sedan and Wagon had different dipstick setups. One was the same as the 914, the other was the same as the Bus. I never remember which was which... (IMG:style_emoticons/default/sad.gif)
Regardless, that motor started life as a 1.7 liter Type IV. Chances are probably better than even that it had the relatively-high compression and D-jetronic EFI that helped it make 80 HP (DIN spec). --DD |
BMartin914 |
Jul 14 2006, 02:37 PM
Now it feels like it makes about 60.
davep |
Jul 14 2006, 03:38 PM
The 411 sedan was what I had, manual trans, same dipstick as 914. Wagon had same configuration as bus (under the floor) low profile.
SirAndy |
Jul 14 2006, 03:42 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
guys, how about the "914 Info" tab on top of each page here ...
W = '70, '71 and '72 1.7L (IMG:style_emoticons/default/rolleyes.gif) Andy |
Lo-Fi Version | Time is now: 7th June 2024 - 09:47 PM |
