No Brake Lights |
No Brake Lights |
germaneighter |
Jul 13 2006, 09:55 PM
Member Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
I do not have any brake lights. I have checked the switch. It is good and adjusted properly. I have blinkers. Fuses are all good.
It's late and I'm getting tired of chasing this thing. Any ideas? Thanks, dave |
grasshopper |
Jul 13 2006, 10:11 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
did they work before??
germaneighter |
Jul 13 2006, 10:14 PM
Yes they have worked in the past.
grasshopper |
Jul 13 2006, 10:17 PM
are the wires connected at the tail lights themselves?
germaneighter |
Jul 14 2006, 09:23 AM
All wires are on the tail light spades, tight and secure. Still no brake lights.
lapuwali |
Jul 14 2006, 12:37 PM
Bulbs?
Have you pulled out a meter and checked for power to the brake light sockets, then the wires, then the light switch, then the correct fuse? |
So.Cal.914 |
Jul 14 2006, 01:26 PM
I am one of those that looks at the most simple answer first, did you check the bulbs?
The fuse? |
Lo-Fi Version | Time is now: 7th June 2024 - 12:39 AM |
