green oil light on ???? |
tod914 |
Oct 13 2003, 09:16 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Is it normal for the green oil light to come on when the door is open? I noticed that when I push in the door buzzer switch it turns off again. I never noticed this before.
Bleyseng |
Oct 13 2003, 09:26 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yes, it doubles as the door open lite. (IMG:style_emoticons/default/laugh.gif)
Mark Henry |
Oct 13 2003, 09:53 PM
No, it's not normal.
But it's an electrical problem, not an engine problem. |
tod914 |
Oct 13 2003, 10:16 PM
any ideas on where to start?
Mark Henry |
Oct 13 2003, 10:27 PM
Electrical gremlins are the worst, get the colour diagram off of this site and an ohm-meter and have fun.
Lotus914 |
Oct 14 2003, 09:02 PM
Newbie Group: Members Posts: 38 Joined: 10-October 03 From: bleak suburbia Member No.: 1,234 |
Does your oil light also come on when the oil pressure is low?
If not, I bet the problem is under the dash, pull out the gauges and trace the oil light wire. Awkward, but easy. You'll probably find those clear square plastic faston terminal junction thingees that allow you to join four wires and it's the door switch junction that someone wired into by mistake. Then look for the lost and lonely faston terminal from your oil pressure sender. I hope its that easy! Dave |
Lo-Fi Version | Time is now: 8th June 2024 - 09:58 AM |
