-6 Flywheel Question, What do I have ? |
914Sixer |
Jul 18 2006, 09:50 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a flywheel that has 901.102.205.0R. When I check in the PET is shows a 901.102.026.01 for the -6. This is the same flywheel as the 911 flywheel up to 69. The 911 PET shows an other flywheel for early engines up to 67 of 901.102.201. Anybody else got one of these flywheels?
I am going to use it on a carbed 2.4. My concern will be about the timing mark on this flywheel. Things that make you go HUM ? |
sixnotfour |
Jul 18 2006, 10:11 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Using any of the cup style flywheels on a 2.4-2.7 ,you will have to make your own timing marks as the bolt pattern is indexed radially different between the short 66 and the long 70.4 cranks.
this link may help (if its a really early one, tooth count) http://www.914world.com/bbs2/index.php?show...=56038&st=0 |
Lo-Fi Version | Time is now: 1st June 2024 - 01:11 PM |
