> Cooling Tips?, Can we keep our engines cool?
tiim5
post Jul 21 2006, 12:52 AM
The recent heat wave in the bay area caused me to wonder if there are methods to 'cool' or otherwise lower the temperature of our engines while we are driving?
I recall an article in Hot Rod magazine years ago, suggesting coasting in neutral,
preferably downhill, as a method to cool a V8 engine. The engine at idle slows the pumping of coolant allowing more time to cool in the radiator. When you would put it back in gear the colder coolant would enter the block and the temperature drop was noticable.
I assume at idle our engines fans are least efficient but at higher rpm more air is moved but operating temp should also increase making this a wash?
Is there anything one can do to get the temp to drop? Is driving at a constant speed, 70 mph for example better than varying speeds?
If the engine gets hot is there any way to cool it down while driving?
Thanks
Replies(1 - 19)
Demick
post Jul 21 2006, 08:45 AM
Ernie made me do it!
Going downhill is not really a practical way to cool the engine. While it does work, big downhills are usually hard to come by whenever your engine is running hot. :-)
The only way my engine cools off is to slow down. The faster I drive, the higher the temps go. So slow down to 55-60 or so and it should cool down. Maybe slowing to 50 and putting it in 4th gear might help even more (higher rpm's provide more cooling air), but I've never needed to try that.
But the motor cools pretty quickly when you shut it down. So taking a 7-11 break is another way to go.
Demick
lmcchesney
post Jul 21 2006, 08:53 AM
The methods I know of are:
External oil cooler with fresh air flow.
Fresh air flow into engine compartment from outside. Someone did a measurment of negative pressures at the engine grill and in the compartment and under the engine. It seem that there was little gradient for flows.
Additionally, I removed every other or kept every third fan blade, which is supposed to improve flow.
Additionally, there is the DTM down the middle modification that can be done.
Larry
brant
post Jul 21 2006, 08:55 AM
how come no one has yet mentioned the most important cooling tool of all?
Jack stands
lapuwali
post Jul 21 2006, 08:59 AM
Not another one!
Even in the recent "heat wave" here, my oil temps are no more than 180-190 at freeway speeds, unless I leave it in 4th and run it up to 80mph, in which case it can rise to 200 or so. Yesterday afternoon on 101, at 50-60mph, I could barely get the oil temps UP to 180. Totally stock cooling system on a Type IV.
Joseph Mills
post Jul 21 2006, 09:23 AM
on a Sonoma diet now...
If you're running carbs, having them "balanced" is paramount.
For that matter, be sure the engine is well tuned (valves, timing, etc).
Have all the engine tin in place and "holes" filled.
Turbulance flaps will help on the highway.
If non of the above does it, move to a cooler climate. (IMG:style_emoticons/default/biggrin.gif)
tiim5
post Jul 21 2006, 11:46 AM
The needle on my stock temp guage moves only slightly to the right even in slow freeway crawl, it has never approched the red nor has it gone to the 'middle' of the guage. I don't know what actual temp is at those points. I guess it is running ok.
I suppose another tactic might be removing the rain tray for summer driving, this should enhance cooling?
Trevorg7
post Jul 21 2006, 01:35 PM
How I cooled my motor on Tuesday during this recent Bay Area heat wave.
Drove from my office, James knows my parking lot all to well – thanks again, in San Mateo to Woodside road, over Skyline, through La Honda, to HGWY 1; winding mountain roads and 30 degrees cooler on the coast than the bay. Down highway 1 to Capitola. Margaritas and dinner at Margaretaville then home to San Jose.
T
Rand
post Jul 21 2006, 01:46 PM
Cross Member
QUOTE(tiim5 @ Jul 21 2006, 10:46 AM) *
Freeway crawl is easy on the temps. It's the high speeds that will push the temps up on these things.
My rain tray is out, but the impact on temps is minimal.
Based on what you say about your temp gauge, sounds like you should just drive and not worry about it.
The stock gauge is only oil temp though, and the head temps are important. If it's tuned correctly you shouldn't have to worry about it under any kind of normal driving conditions. But a vdo head temp gauge is a good $80ish well spent just to know where it's at.
turboman808
Ceramic coating and header wrap.
tiim5
post Jul 21 2006, 02:38 PM
Hey Treavor,
I know that drive, very nice, scenic and lots of curves. How's the Bursch working out?
Thanks for the tips, I guess I am running fine, with 33 year young cars constant concern is our co-pilot.
So.Cal.914
post Jul 21 2006, 02:42 PM
"...And it has a front trunk too."
This would not be my first choice but I'm sure it would work, drive it into a lake. Shy of
that extreme just keeping my foot out of it makes a big difference.
McMark
914 Freak!
Ed, there's not a lot that can be done while driving, other than slowing down and raising the fan speed (more RPM). 5th gear can be a killer on the engine if the RPMs are low. But there is nothing comparable to the turn-on-the-heater trick in water cooled cars.
BTW, I got your 'letter'. Thanks! (IMG:style_emoticons/default/biggrin.gif)
Trevorg7
post Jul 21 2006, 02:43 PM
Hi Ed - The drive was great and the bursch is working well. Still have not put the HE on yet...in due time.
Thanks
T
Joe Ricard
post Jul 21 2006, 06:27 PM
CUMONIWANNARACEU
Have you tried tuning it?
the correct mixture of gas and air does wonders for head temps and oil temps.
all the tin and gromets in place, clean fan blades, clean tin and clean oil cooler.
Headers can cool them down and timing is the #1 heat maker.
McMark
post Jul 21 2006, 07:10 PM
914 Freak!
This was a hypothetical question. He mentioned his car doesn't even reach halfway to the red. (IMG:style_emoticons/default/wink.gif)
krazykonrad
post Jul 21 2006, 07:24 PM
I've heard that synthetic oil will run much cooler than regular, but dont have any numbers at hand to back this up.
Konrad
McMark
post Jul 21 2006, 07:38 PM
914 Freak!
Jake Raby has posted that he found as much as a 10 degree F drop in oil temp based on oil choice. But I'm not sure which oil it was. If you made me guess, I'd say Royal Purple.
cnavarro
post Jul 21 2006, 07:53 PM
Cylinder Guru
It was Royal Purple. I'd say the best RP choice would be the max cycle 20w50. That's what I run in my high-strung 912. After 4000 mi and an average of 220-240 sustained oil temps, the TBN dropped from 8.5 to 6.5 roughly and the Zn and P where barely affected. Change in viscosity was nil. I'd say that RP recommendation of 15,000 mi is well earned. I'll just change it more often since it doesnt cost that much with so little oil. Not like my wife's W8 Passat - it takes more oil than my 911.
McMark
post Jul 21 2006, 07:57 PM
914 Freak!
Yay! I remembered something. Thanks for popping in Charles.
- Lo-Fi Version Time is now: 4th July 2025 - 04:43 PM
