JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,548 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
FWIW
"The engine is a 1641cc flat-4 engine. I recently rebuilt it. It has 87mm forged pistons, Rebuilt conrods, stock crank, MOFOCO 110 cam (equivalent to a scat c25), rebuilt cylinder heads. Redline is around 4750 rpm. This is a strong engine. It has the Megasquirt fuel injection controller. The injectors are Mustang 19 lb/hr rated, the throttle body is off of a 95 ford escort, the turbocharger is off of a 2003 Audi A4. The computer is tuned to run 20 psi should you desire to push it that far. It does have a manual boost controller set to around 10 psi. It is also equipped with a blow off valve for that highly desired WHOOOOOOSH!!!! It is setup as a blow through. The engine is equipped with a MSD Boost Timing Master. It retards the timing under boost and is adjustable. " Attached image(s) ![]() ![]() |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Thats a TYPE THREE engine... NOT a Type 4..
Totally different animal.. |
Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
He never said it was a type 4, flat 4. Always liked fastbacks and notches, good color too.
Lo-Fi Version | Time is now: 16th June 2024 - 02:51 PM |
