krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
I found out today that the rocker arm studs on my "new" engine are broken. The PO put it in shortly before he sold it to me. Is this something I can do myself? The price that wa quoted to me for fixing it is going to put the teener in the garage for a while! (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) !!
Thanks! Konrad |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
finding the replacement studs can be a prob....
torque spec for them is reaaallly low..... stripped? if you can get it out, you can put a new one in.... |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Is it the stud or the head that stripped? If the head drill, tap and put in a helicoil (I
probably spelt that wrong) if the stud check with Jake Raby. |
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
If it's just that the threads are stripped, easy fix, if the stud broke flush with the head, it's more complicated. If you have a steady hand it is possible to weld a bolt to what is left of the stud and simply unscrew it. On my 912E the stud broke dead even with the head and it came out clean. Either way, pretty common and shouldn't require the head to be pulled.
Lo-Fi Version | Time is now: 17th June 2024 - 11:58 AM |
