Engine Grille Color, Gloss, Semi Gloss, or Satan Black? |
Lou W |
Sep 23 2006, 05:46 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I'm sending the grilles out to be powder coated, I'm not sure what the finish should be, what do you think?
tod914 |
Sep 23 2006, 07:17 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Semi gloss. Check the engine tin thread in the main. Jeff posted the
cooresponding PC number. It should also be in here on another thread. Hope that helps |
Lou W |
Sep 23 2006, 08:05 PM
Thank You (IMG:style_emoticons/default/beerchug.gif)
914runnow |
Sep 23 2006, 11:06 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
I'm sending the grilles out to be powder coated, I'm not sure what the finish should be, what do you think? BK -05 is what you want..I was able to sneak in under the wire.. and get the left and right outer grilles NOS/OEM before they were unobtainium.. The center grille was gone for a while.. SO I have matched them up to my tin that is BK-05.. 90% correct..I also had 4 done by the powdercoater.. re those outside grilles...Again 90%.. Our OEM's on the car have U/V faded.. so they look more like a satin/flat black.. Oh and engine heat helps in the fade... |
Lou W |
Sep 24 2006, 09:10 PM
I'm sending the grilles out to be powder coated, I'm not sure what the finish should be, what do you think? BK -05 is what you want..I was able to sneak in under the wire.. and get the left and right outer grilles NOS/OEM before they were unobtainium.. The center grille was gone for a while.. SO I have matched them up to my tin that is BK-05.. 90% correct..I also had 4 done by the powdercoater.. re those outside grilles...Again 90%.. Our OEM's on the car have U/V faded.. so they look more like a satin/flat black.. Oh and engine heat helps in the fade... Good info, Thank you |
Lo-Fi Version | Time is now: 10th June 2024 - 09:13 AM |
