level914 |
Member ![]() ![]() Group: Members Posts: 68 Joined: 2-November 03 From: Sparks, Nv Member No.: 1,300 ![]() |
I have been told that I need a high torque starer for my 914. It's a 1976 2.0 and it has sat for some time, five plus years. I have had the starter that I have in it now tested and they say it looks fine. The problem I have is that the starter will turn the motor with no plugs in, but if I put one in, the starter fights past the one cylinder. If I put two plugs in it kills it completely. I assume maybe its more than just the starter, so I don't know if I should purchase the high torque one yet. Any help would be appreciated. By the way I do have a new fully charged battery and new ground and positive wires. I'm getting 13.8+/- volts to the starter. I'm a real big rookie at this.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(level914 @ Nov 2 2003, 10:25 AM) I have been told that I need a high torque starer for my 914. told by whom ? not someone who claims knowledge of 914's i hope ... if i still lived in Minden like i did this time last year, i'd be up there to help you like a shot. as it is, i don't know a lot of 914-knowledgeable people in the area any more... your voltage to the starter is good. now you need to make sure your ground path is just as good. check out the negative terminal at the battery, al the ground straps, and especially the transmission ground strap. by 'check' i mean remove, clean to shiney, replace. this is presuming you don't have ultra-high racing pistons or other unusual stuff you haven't mentioned ... it's possible the starter is gummy and gunky from sitting, and has developed corrosion or oxidation on the commutator. it's a PITA to R&R the starter but not horrible. (check out a decent repair manual, such as the Haynes, because there's at least one starter fastener that's non-obvious...). pull it, check the condition of the solenoid grease, look for corrosion on the commutator and clean that up a bit, lubricate as indicated, re-install, and see if that helps. how hard is the engine to turn by hand ? another possibility is that the cylinders have filled up with water or something and are hydrolocking. or just that the rings have rusted in place - but that isn't typically a big problem in Northern Nevada ... let me recommend you join the Sierra Nevad Region of PCA; it's a great bunch of people and while there aren't really very many active 914 people, there are people who can probably help you - especially now that the vintage racing season is drawing to a close... |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Ground strap from tranny to body is broken or missing.
You dont have a street driven 2.0 engine that needs a high torque starter. B |
Brad Roberts |
Oh.. welcome to the BBS. (IMG:style_emoticons/default/clap56.gif)
Had you posted a few weeks back I could have stopped in and helped you while I was on my way back to SF through Reno. |
level914 |
(IMG:style_emoticons/default/boldblue.gif) Thanks a million. The strap was frayed and separated from the stud. You guys saved me tons of time and money. If there is anything I can do in the future for you don't hesitate to ask. The starter turns the engine like a champ now with all four plugs in. Im moving on to the next phase now. Im sure I'll have alot more questions. For instance how important is my deceleration valve? Again, thanks for the info.
level914 |
(IMG:style_emoticons/default/confused24.gif) By the way, the person that told me I needed the high torque starter, was at the auto parts store that tested my starter. He (I swear) had a German accent. I thought that was supposed to mean he was the ultimate authority on these matters. You guys rule (IMG:style_emoticons/default/pray.gif)
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
He probably started speaking with that accent when you asked about Porsche parts. (Makes the price seem easier to handle) (IMG:style_emoticons/default/laugh.gif)
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,663 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
I vote this to be a "classic" thread.
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
QUOTE(GWN7 @ Nov 5 2003, 08:39 AM) He probably started speaking with that accent when you asked about Porsche parts. (Makes the price seem easier to handle) (IMG:style_emoticons/default/laugh.gif) Like Pete Hussey! M |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
no profit in a $5 ground strap. "anything you can do in the future"? buy a sticker and contribute to the tow fund. see my avatar or boxtrs.
kevin |
Brad Roberts |
Most of us here responding have "been around the block".
Fire away with your questions. And no.. you dont NEED the decel valve. Its semi smog related for when you come off throttle quickly. It brings the car to idle slower than normal. B |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(level914 @ Nov 5 2003, 04:30 AM) He (I swear) had a German accent. I thought that was supposed to mean he was the ultimate authority on these matters. no! as i have repeatedly demonstrated here on this board, we (se Germans) are not the ultimate authority on these matters ... (IMG:style_emoticons/default/laugh.gif) Andy |
Lo-Fi Version | Time is now: 12th July 2025 - 10:48 AM |
