> How is oil pressure relief handled?, in my '76 GC without the valve???
jk76.914
post Oct 5 2006, 02:21 PM
I have a '76 2.0 with GC case. There is no oil pressure relief valve in the case. The one between the pushrod tubes at cylinder 1. Just a deep hole, as cast.
So how exactly did VW handle oil pressure relief in this case? The engine ran just fine, and extremely reliably for 98000 miles, which is when I tore it down to rebuild it.
Jim
Replies(1 - 3)
Brad Roberts
post Oct 5 2006, 03:29 PM
914 Freak!
I beleive they left them out because of the hydraulic lifters needing more oil than the solid lifter engines. They changed the casting for the Buses with hyd lifters.
They probably figured out they didnt need it. Most of the race engine builders I know prefer that case. One less thing to fail.
The worst that can happen: more oil in the heads under sustained high RPM driving.
B
Dave_Darling
post Oct 6 2006, 04:37 PM
914 Idiot
The way it works is that the valve at the front end of the motor does the work. Instead of having one valve at the "end" of the system that opens up when pressure gets too high, and another one at the "beginning" of the system that does approximately the same thing, they just went with the one at the beginning. That's the one that is covered by that plug with the large slot in the end...
--DD
jk76.914
post Oct 6 2006, 11:22 PM
Thanks for the replies. What I couldn't figure was that since VW went to the the so-called dual relief cases in '69 or '70 to solve some problem, isn't my case open to having whatever that original problem was again?
Also, looked it up in my parts book, the relief valve near the oil cooler parts are exactly the same numbers as in the earlier engines that also have the relief valve at the other end. So all they did was take the pressure relief valve out. No mods (apparently) to the other relief valve to compensate.
I know that the hydraulic cam cases don' t have the pressure relief valve either, but my case is a '76, and the hydros hit in '78 (IIRC), so I'm not so sure VW got that big a jump on the planned switchover to hydraulics. Maybe, though.
Oh well. Seems to work fine, so I'll worry about other things instead.
Thanks again,
Jim
- Lo-Fi Version Time is now: 9th July 2025 - 12:09 PM
