rtalich |
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None ![]() |
Looking for a good machine shop in the area that know what they're doing.
Any recommendations? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
for what work, specificly?
k |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
for your engine needs except heads:
NorthWest Connecting Rod, Jerry is the owner in SouthPark area |
rhodyguy |
yep. pretty quick turn around.
rtalich |
Bleyseng |
Len at HAM inc (Hoffman Auto Machine) in Georgia does 914 heads the right way.
Adrian at Headflow Masters in Calif does good work. Those are the two I know do good work and the seats will not fall out. Len also does have little things like HD springs, nice valve retainers, better valve spring retainers...for a little more rpm that stock. Len works with Jake to produce the LE heads which are ported/milled by a CNC for excellent results. What needs to be done?? Bigger valves? stay with a max of 44x38 to keep port veloicity up. Cams? go to Jakes store for a cam and matched lifters. His don't go flat. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:42 PM |
