Anyone know who sells main bearing dowel pins?, long story |
dadsscooter |
Oct 16 2006, 06:29 PM
Newbie Group: Members Posts: 7 Joined: 28-September 06 From: Michigan Member No.: 6,938 |
I have two cases...one with the five dowels ...one without any. Some idiot (me) used extra strength loctite during last rebuild on them. Cant get the buggers out .
I have tried several different tools and penetrates. Starting to screw them up. At this point am looking for 5 new ones. Anyone know who might sell them??? |
StratPlayer |
Oct 16 2006, 06:58 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Jake has them in his type 4 store,, look under crankshaft page #3 I think.
http://www.aircooledtechnology.com/store/home.php |
dadsscooter |
Oct 16 2006, 07:50 PM
Thanks... I must have missed them. I'll check again
Bartlett 914 |
Oct 17 2006, 06:42 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Did you get them out? loctite will break down with a little heat. I did say little. Another option is to drill and tap for about 4mm thread. make yourself a slide hammer that has a long 4mm set screw in the end. Use this to pull them out. Dowel pins are not that hard to find. You may even find them in your local hardware store. The length is critical. You will need to cut them to length. If you get hard ones, then grinding them to length will need to be done.
Lo-Fi Version | Time is now: 7th June 2024 - 07:12 AM |
