914 Alignment Day at CFR coming soon!, Saturday, Nov. 4 in Manchester, CT |
ChrisFoley |
Oct 19 2006, 02:51 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm going to set up my alignment platform for a get-together at the new shop.
Get your 914 (4 wheel) aligned for $35 plus cost of rear shims. Saturday, Nov. 4th - 10am to whenever; rain day - Sunday Nov. 5. Who's coming? RSVP |
turboman808 |
Oct 19 2006, 02:59 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I'm going to set up my alignment platform for a get-together at the new shop. Get your 914 (4 wheel) aligned for $35 plus cost of rear shims. Saturday, Nov. 4th - 10am to whenever; rain day - Sunday Nov. 5. Who's coming? RSVP Oh I will be there (IMG:style_emoticons/default/piratenanner.gif) |
jd74914 |
Oct 19 2006, 04:42 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'd be in if I could get my car over there . . . hmm
That probably pretty unlikely tho (IMG:style_emoticons/default/dry.gif) I might just stop by to see some cars (IMG:style_emoticons/default/smile.gif) |
RS22b |
Oct 19 2006, 05:03 PM
Type Broken! Group: Members Posts: 223 Joined: 8-January 05 From: Vernon, NJ Member No.: 3,425 |
i think i would be in for that. Same as above, if i can get my car to start and actually drive that far it would be awesome. Hopefully have it all sorted out this weekend.
_billy |
turboman808 |
Oct 19 2006, 05:08 PM
mskala |
Oct 19 2006, 07:33 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Wow, even though I align myself I would be into that if you weren't so
far, and I wasn't so busy with other stuff. Thanks, |
sixerdon |
Oct 19 2006, 08:01 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Sounds like a plan. I'm open on that date and it's not far for me. I'll RSVP when we get closer. I'll try to grab a teener friend.
Don |
firstknight13 |
Oct 19 2006, 09:15 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/biggrin.gif) chris i'm in too!!! and if you see heidi tell her i have her part....s too!!!!!!!!! (IMG:style_emoticons/default/clap56.gif)
pfierb |
Oct 20 2006, 03:20 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Chris, I will be there my car could sure use an alignment.
Need directions from 84 east...Thanks Paul F. |
scottb |
Oct 20 2006, 03:34 AM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
oooh! i should be able to make it as well! (IMG:style_emoticons/default/mueba.gif)
this is just the push i need to tighten a few things back up after storage and maybe even find time to swap out my horribly slipping clutch. or i could just show up, oil leaks, slipping clutch and all!! |
ChrisFoley |
Oct 20 2006, 05:12 AM
or i could just show up, oil leaks, slipping clutch and all!! That's the spirit! (IMG:style_emoticons/default/beer.gif) Actually the clutch might be a good thing to work on before venturing out of state. (IMG:style_emoticons/default/unsure.gif) I'll post directions here. |
ejm |
Oct 20 2006, 07:57 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I'm planning to be there... just to hang out.. no alignment needed
Scott... call me if you want a hand with the clutch |
firstknight13 |
Oct 20 2006, 08:44 PM
(IMG:style_emoticons/default/biggrin.gif) BUMP!!!!! hey you guys... LETS show our support for CHRIS!!!!!! he is striving to be the go to guy in our area and with his help which i know we all can use we will all be better because of it !!!! (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/mueba.gif)
blabla914 |
Oct 21 2006, 07:20 AM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Chris,
Nice deal. I'm assuming if I just want readings with no adjustment that would be OK? I'd like to see if my car is what I think it is. I don't suppose you have scales too? I'm about 80% good for this right now. I'll let you know as we get closer. Kelly |
ChrisFoley |
Oct 22 2006, 05:45 AM
Chris, Nice deal. I'm assuming if I just want readings with no adjustment that would be OK? I'd like to see if my car is what I think it is. I don't suppose you have scales too? I'm about 80% good for this right now. I'll let you know as we get closer. Kelly I have a low budget (digital) scale setup that works on the same platform. We can corner balance your car instead of adjusting the toe/camber. |
ChrisFoley |
Oct 23 2006, 04:07 PM
just keeping it near the front |
turboman808 |
Oct 23 2006, 04:44 PM
I'm a bit confused by corner balancing. What are you trying to acheive exactly. And also I never hear anyone talk about tire size when doing this. Wouldn't you want to take into account how much rubber you have in the front compared to the back when balancing the car?
I noticed after switching to larger tires in the rear I could play with the brake bias and get alot more braking out of the back without locking up. So at some point tire size shouold be considered I imagine. |
E-Man |
Oct 23 2006, 08:33 PM
Member Group: Members Posts: 158 Joined: 4-March 03 From: S. Windsor, CT Member No.: 390 |
Good timing! I just rebuilt the whole front-end and need to have that done. I'll call you about other work needed too.
-Mike D. |
ChrisFoley |
Oct 24 2006, 05:43 AM
Nathan,
Corner balancing is not for changing the front/rear weight bias. The primary value is to eliminate cross-weight (usually from incorrect torsion bar adjustment). When that occurs two diagonal corners of the car carry more then half the total load and handling is negatively affected. To do a thorough competition alignment it is necessary to have the driver's weight in the car, the tires inflated to operating pressure, and the anti-sway bars disconnected. Corner weights should be checked before other alignment parameters are adjusted since altering the ride height of a corner will change both camber and toe. I've had good success getting corner balance in the ballpark just by measuring ride heights (at key locations) carefully. |
E-Man |
Oct 25 2006, 08:53 AM
Lo-Fi Version | Time is now: 16th June 2024 - 11:05 AM |
