Speedo doesn't work/Odo does, checked the archive |
scottz0369 |
Oct 19 2006, 10:23 PM
Newbie Group: Members Posts: 23 Joined: 30-September 05 From: 29 Palms, CA Member No.: 4,894 |
I checked the archive as best I could on this, but didn't find something similiar---
My speedo quit, but the odometer and trip odo work just fine. I pulled the cable end from the speedo, and the shaft turns just fine while driving. Do I need a new speedo? Scott ps-thanks in advance for the assist..... |
bd1308 |
Oct 19 2006, 10:39 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
okay, in your speedo you have a cup that turns when a magnetic force is spun close to it.
Mine had grease in between that cup and the bore in which the cup sat, and I had no speedo. Take the speedo apart and you'll see what i'm taking about. |
So.Cal.914 |
Oct 19 2006, 11:22 PM
www.nhspeedometer.com
Fix you right up. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:11 PM |
