Step Studs, Stripped head |
BMXerror |
Oct 20 2006, 06:42 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Anyone ever stripped the threads out of the head with the exhaust studs. Well, the guy who owned my car before me put studs that were too short in and they didn't bite on enough thread. He tried to tighten them with not enough thread and stripped the head out. To the point, does anybody make T4 step studs? If not, has anyone else encountered this problem (doubt I'm the only one), and if so, how did you fix it. I went to four places looking for step studs today with no luck, so any help would be great. Thanks.
Mark D. |
DNHunt |
Oct 20 2006, 07:46 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I know there are 9mm X 8mm studs cause I've used them and I think there may be 10mm X 8mm but I haven't personally seen them. Not too tough a job.
Dave |
brp914 |
Oct 20 2006, 09:06 PM
Unregistered |
I put in a helicoil, which has held up a couple years so far. I wouldn't call it easy. If the engine is in the car and you're lying on your back, it's cold out, and you haven't used a tap before, and aren't familiar the consistency of 914 head material (which is soft). Well, there is the danger of having the tap go in the wrong direction making it difficult to install your exhaust, or worse, having the tap merely drill a hole. good luck. the factory tapped farther into the head than is used by the stock studs, which is probably why you found "short" studs.
davep |
Oct 20 2006, 09:14 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm having Len set me up for step studs on my heads. My threads are not bad, but I want it done correctly this time around.
So.Cal.914 |
Oct 21 2006, 12:42 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Timesert's will take care of the problem very nicely. They are quite strong and
not to bad to install. |
HeloMech |
Oct 22 2006, 12:37 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
VeeDub parts down here in HB has standard 8-8 studs for $1.. .the steps 8-9 and 8-10 are $3 each. I just bought some yesterday for a coworkers 914.
jk76.914 |
Oct 22 2006, 10:09 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
earlier I recommended 8/9mm step studs on the other parallel thread that's going on right now.
So then today, I went out to the garage to checkout this tiny putt-putt exhaust leak I thought I had, and what do you know? The only 8/9mm step stud I put in my engine when it was rebuilt 1000 miles ago had pulled. So now I think that unless you're SURE about the quality of your stripped 8mm hole, you should go with the 8/10mm step stud. That way you'll get to good solid aluminum almost for sure. I'm thinking now about a timesert to repair mine. My stripped out hole is about 9mm, and rough, so I'm not that sure it'll hold even the 10mm for the long run.... |
Lo-Fi Version | Time is now: 11th June 2024 - 08:23 PM |
