Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
When I had pulled my trans and engine in the assdragger six months ago for the second gear
repair, the outboard boot(s) looked fine...the inboard CVs had plenty of grease. I should have pulled the splines off and looked inside. It was dry...very dry but there no evidence of thrown grease anywhere....odd that. I slapped in a known good set of CVs and axles....no more clunk.... I guess I'll service this one....see if the balls and cage are savable and then pull the other side....since I have an LSD I would assume the other may be in the same condition or close to it. So the moral of the story....do the inspections and you won't have to do it later......since the 914 CVs are NLA....you might want to save as many as you can. BTW....My 911 only has 88K original miles....but 35% more HP......imagine what a 914 CV and a V8 would look like. |
Joe Bob |
What? No comments..or should I put naked pics of Howie in here?
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,289 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
No pics of Howie, PLEASE!
Anyway, the problem may have been that the CV's were not properly filled the last time. I remember years ago getting little tubes of CV grease, possibly Lobro, but there was two sizes, 50 & 60 ml. One tube was supposed to do a CV. So what was the correct amount? I think a little extra is better than not enough as long as you don't go overboard. Just found a pair of used CV's. Bolted to a good looking tranny with the shafts torched into short stubs. |
Joe Bob |
I doubt that they had ever been serviced. They had the oem bands on the boots.
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,293 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Well I took a diff. path to rebuilding my CV's.
In the resto work of the LE the half shaft looked pretty bad rusty and peeling the OE paint/pwdr coat. So I tore them down only to find while the cages & body were in decent shape no pitting or scars buts the balls were TRASHED. (IMG:style_emoticons/default/blink.gif) Tore some others I had apart to see if I could find some good ball bearings and those are trashed too? So now the shafts are blasted and newly powdercoated Im just gonna replace the ball bearings and renew. (IMG:style_emoticons/default/smile.gif) |
Joe Bob |
I bought four sets of oem CVs for my 914......since I have been know to blow them up....it's a wise investment for me....
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
When doing said inspection, be sure to pack liberally with grease.
Also remember to wear a white shirt and expensive courdoroy pants (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 2nd July 2025 - 07:26 PM |
