73jef74 |
Member ![]() ![]() Group: Members Posts: 50 Joined: 24-June 05 From: Spokane, WA Member No.: 4,324 ![]() |
Is Bosch Part Number 0 280 130 012 or Bosch Part Number 0 280 130 017 the correct part or is the correct part some other number?
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
pelican lists CHT by VW/Porsche number
http://www.pelicanparts.com/catalog/shopca...j_pg2.htm#item6 73 2.0 022.906.041 |
root |
Two Wheeled Type4 Completed! ![]() ![]() ![]() Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None ![]() |
FROM THE WORKSHOP MANUAL - page #0.1-3/2
Effective as of: August '73 - 914/2.0 Temp Sensor II (CHT) = 022.906.041 there's also a note saying " Ballast resistor discontinued." (IMG:style_emoticons/default/smile.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
017with a 270ohm resistor
Pelican Parts has or can order both for about $30 each. |
73jef74 |
Recent order from Pelican Parts resulted in 022-906-041-A-OEM and 0 280 130 012. According to the pbanders guide on 914 D-Jetronic Parts and Troubleshooting, the above part is for 2.0L 1974-1976 and the part should have been 0 280 130 017. Anybody know what is going on here?
Bleyseng |
Did you call PelicanParts?
You must use a 017 with the 73 2.0L Djet to have it idle along with a 270 ohm resistor. Try Dave at German Parts & restoration as he surely has some. |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:13 AM |
