Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
I've lost my steering wheel nut and washer. Is there anywhere local where I can find something as a replacement (I think I read it's 27mm?)? Osh only carries up to M12 sized nuts, local bug shop says they don't have any. Also I think I remember that washer being a special "wavy" kind or something.
Same thing for the nut that holds the clutch pedal tight, lost that too. (IMG:style_emoticons/default/dry.gif) Any idea on size of that? thanks.... |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
How soon do you need it?
I'll take a look in my parts car and see if there's one rolling around. |
Allan |
Found the nut and the wavey washer.
What's your address? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Easy ..... the man's losing his nutz
PORobinSCHE |
Member ![]() ![]() Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 ![]() |
i am more worried about the fellow that found his nutz. hope he used a glove (IMG:style_emoticons/default/bootyshake.gif)
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If the "other" nut you've lost is the one on the transmission end of the clutch cable, it's a standard M7 nut. Takes an 11mm wrench, usually. Use two regular M7 nuts and tighten them against each other so they don't "self-adjust" while you're driving.
--DD |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
There are plenty of metric nuts on this site.
Lo-Fi Version | Time is now: 11th July 2025 - 03:20 AM |
