> Mr Louver.......Louver, which way should they face??
East coaster
post Nov 7 2003, 09:11 AM
If I were to punch louvers in the front portion of my engine cover (instead of the usual GT grill mod), which way should they face, front or rear?? I know some of you 914 aerodynamicists out there will know (IMG:style_emoticons/default/wink.gif)
Replies(1 - 5)
Hi_Fi_Guy
post Nov 7 2003, 09:38 AM
Tuetonic terror
I am guessing hey should face rear to exhaust heat out f the engine bay.
maf914
post Nov 7 2003, 10:19 AM
Not a Guru!
I would bet that if you stamp louvers into the solid metal panel the direction will make almost no difference to cooling. Air is drawn into the engine by the cooling fan. You are adding more free area which will help, but since there is probably little or no smooth airflow in the grill area, sheltered by the rear window and sail panels, the direction of the louvers is probably not important. Maybe there is some reverse flow from the rear deck toward the window, in which case having the louvers open toward the rear might help. Plus, as far as looks go, rear facing would probably look better.
Mike
scotty
post Nov 7 2003, 10:22 AM
The Fun Never Stops
...especially in the looks dept.
Why not slots instead? I think that would look/work good, especially if you roll the edges down. More work though...
Qarl
post Nov 7 2003, 10:53 AM
Shriveled member
You could have the louvers facing down INTO the engine compartment and not have them protrude up from the top....
Curvie Roadlover
post Nov 7 2003, 12:06 PM
Two trunks are better than one!
QUOTE(kellzey @ Nov 7 2003, 08:53 AM)
I think THIS would look the coolest (IMG:style_emoticons/default/wink.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 10:46 AM
