throttle valve, replacement |
will |
Oct 31 2006, 11:42 AM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
I can remove my throttle valve body and clean it? How often does this part break? How do I know if I need a new one?
thanks, will |
Bleyseng |
Oct 31 2006, 11:48 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
You can take it off and clean it.
Look for a sloppy shaft that wiggles in the body. If its shot you can have bushing installed which makes it operate nice and smooth without creating a vacuum leak. Look at the TPS while you are at it. pop off the cover carefully and clean the traces/arms with a electronic contact cleaner. works wonders unless the traces are completely shot/worn out. Reset the TPS via the PelicanPart article. Then reinstall the Throttle body back on the engine. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:36 AM |
